Question about Magic Chef Microwave Ovens
I have a magic chef microwave that heats well but when the door is closed it hums and get really hot on top while not in use. Eventually it will stop working all together until it cools down then I can plug back up and it works again. As long as the door is open it is fine but as soon as the door is closed it starts to hum and heat up, again while not in use. Is this worth repairing. Model number is MCM1110ST
    Scholar:
  • 178 Answers
This one actually sounds like the unit is cooking when the door is closed without blowing the fuse as it is supposed to do. Unplug it from the wall and let it cool down, which it probably already is. Put a cup of cold water in it, close the door and plug it in for one minute. Unplug it from the wall and check the water. Did it heat up? I'd bet that it heated the water up. Sometimes the cook relay sticks closed and it stays in cook mode. This condition is supposed to blow the fuse but really rarely it doesn't. I've only seen this happen 3 or 4 times out of about 14,000 units I have looked at in my career.
It would need a new control PCB and new door switches and probably a new magnetron.
Posted on Oct 28, 2013
SOURCE: Magic Chef Microwave
problem solved
Posted on Jul 07, 2008
ginko
  • 19396 Answers
SOURCE: GE SPACEMAKER JVM1650
When door open the microwave should not work at all, if the turntable and light come on with the door open , if they do , then this is an additional problem with door switch and must be fixed.
Regarding humming noise and no heath, Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
heatman101
  • 43501 Answers
SOURCE: Microwave Model JVM 1870 stopped heating, all else works (timer)
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ggk
Posted on Sep 30, 2010
KevinWhite
  • 1902 Answers
SOURCE: My magic chef microwave model
Hello & Welcome to FixYa
The door switch is bad and needs replacement, as it is bad so the control senses that the door is not closed so won't heat. Please get back to me if you have any other questions.
Kevin
Posted on May 14, 2011
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Dec 26, 2012 | Magic Chef Microwave Ovens
My Magic Chef microwave tripped a breaker,I found a melted door switch and replaced it, the other three test ok.With the door closed everything works like new. When the door is opened the breaker blow
The only thing I can think of is check to make sure all switches are aligned correctly otherwise you will keep tripping the breaker, I'am certain that one of your switches are not properly in position.
Jul 07, 2012 | Magic Chef Microwave Ovens
The microwave fuse keeps blowing up. Any idea why?
My Magic Chef microwave keeps blowing fuses (5 fuses) when close the door. Anybody has any idea? It is the first and last time time that I buy Magic Chef's products if their enginers don't come out with a solution because I just got it just over a year.
Thanks for your time and your expertise.
May 12, 2011 | Magic Chef MCO160UQ Microwave Oven
My magic chef microwave doest heat up
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 04, 2011 | Magic Chef MCO160UQ Microwave Oven
Microwave Won't Heat
Check the door safety interlock switches. Be careful of the capacitor, potentially dangerous.
If the switches dont make a connection, the magnetron will not energize ... no heat
Apr 19, 2010 | Microwave Ovens
No heat on magic chef microwave
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Will run but not heat , majic chef, model mcd990arw
check the door switches ... they are probably burned preventing preventing the machine from knowing the door is closed.
Oct 19, 2009 | Magic Chef MCM1290A Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
