Question about Honeywell Homexpert Heating Controls Thr842duk Wireless Digital Remote Thermostat
The thermostat will not turn my boiler on I can do it by pressing the reset button but the wireless thermostat will not turn it on or off
Changed the batteries in timer/thermostat but the boiler is still not talking to the transmitter heating still on can you help??
Is this a wireless system, meaning no wires between the thermostat and the boiler? If so, check to see if the code buttons have been reset. If this is a hardwire system, the relay on your control board may be stuck. In any case, you can always shut off the boiler by turning off the gas and/or circuit breakers.
May 31, 2016 | Water Heaters
Reset button on coleman gas furnace
Reset by turning off thermostat, waiting a minute then turning back on. Turning off the thermostat resets the board.
Feb 09, 2015 | Coleman 7990-319p Evcon Gas Furnace...
How do you reset the thermostats on the rancilio?
Safety thermostat for rancilio silvia is on the boiler and has a red button on top.Press this button down and you should be ok.
Other thermostats cannot be reset - just replaced.
If the boiler temperature exceeds 165 degrees Celsius, this thermostat will trip, cutting power off from the element. This is done to try to prevent element damage due to overheating.
Mar 25, 2014 | Rancilio Silvia Espresso Machine
How do I reset the thermostat on the Rancillio?
By removing the top four screws on the lid (with the water tank removed) and looking inside the machine you will see three (3) thermostats. The two (2) thermostats on the top of the boiler do not reset. Leave those be. The 3rd thermostat which is mounted on the side of the boiler facing the front near the switches is the safety thermostat. If you look closely you will see that in-between the connectors is a small circular button. Carefully push this in with something long and narrow (not an object that will conduct electricity) and the thermostat will have been reset. If this does not work and the button does not press in, you will need to replace the safety thermostat.
Jul 27, 2011 | Rancilio Silvia Espresso Machine
Worcester 24i boiler..how do i re-ignite the pilot light??
Overheat thermostat has tripped. If a modern Worcester need to press reset on control panel.
If older style Worcester - Pull front cover off the boiler (just above control panel flap pull the cover from both sides forward to unclip and then lift upwards to remove cover) and you will see a little brown reset button - press this back down.
However the over heat thermostat trips for a reason - was the system running on low pressure? It could be the pump is sticking a bit (dirt in the system) which can be sorted easily by adding an additive (DIY packs available at Home-base) . Or it could be the pump has completely gone. If this is the case it will trip again as soon as the boiler clicks back on.
Apr 27, 2011 | Heating & Cooling
Machine just stopped working. dead
Hi
If the machine is less than 4 years old there are reset buttons on the outside edge of the boiler. There are 2 wires going to 2 thermostats. In between the wires on the thermostats are reset buttons. 1 on each thermostat. They are hard to get to but they might restore you machine. if not it could be your PCB board.
If its older than 4 years there is a reset button on the back of the boiler with just 1 thermostat. Reset button between the wires again.
Jan 02, 2011 | Saeco Vienna SuperAutomatica Coffee...
Need to learn about the electrical system. My coffee machine does not turn on,
There are 2 reset buttons on the side of the boiler if you have the neew J boiler.
If you machine is older, there is a reset button in the back of the boiler towards the bottom of the boiler. Push in between the 2 wires on the black thermostat on either boiler. Its harder on the J boiler because the thermostats are between the boiler and the side of the machine.
Oct 01, 2010 | Spidem Trevi Digital Coffee Maker,...
Where is the reset button on the rancilio audrey?
Once you get the top off, there are 2 thermostats on the top of the boiler. Your looking for the thermostat that is on the front of the boiler with the red button . Push the red button. If that didn't work check the ohms reading on the element. It should read 12 - 16 ohms. If it doesn't replace the element. Also did you try to turn on the steam button? Sometimes the thermostat with the red dot on it goes bad. If it will steam just replace the brew thermostat.
Feb 09, 2010 | Rancilio Audrey
Boiler going into reset I think it could be the thermostat
Changing the t-stat will not keep the boiler from tripping out. Sounds like you need to have the boiler serviced.
Jul 06, 2009 | Desa International GWP20T GLOWARM Wall...
Honeywell Homexpert Heating Controls Thr842duk Wireless Digital Remote Thermostat Logo
29 people viewed this question
Top Honeywell Televison & Video Experts
Ron Durham
Tom Chichester
Are you a Honeywell Televison and Video Expert? Answer questions, earn points and help others
