Question about Dryers
My 16" standing lasko fan stop work all a sudden,it have bout 1yr and 6mths,
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
Could be a bad connection in side the line cord. with the fan plugged in & running try wiggeling, bending and streaching the line cord, especially where it comes out of the rubber plug at the end of the cord and where the cord hooks into the motor.also,take a pocket screwdriver,unplug the cord from the wall and look at the two prongs of the plug.some plugs are made of two stripes of copper, folded over at the tip of the prong. a screwdriver can be inserted between the left and right sides of the one prong and you can pry the two copper stripes apart about 1/16 to 1/8 of an inch. this makes a very tight connection when you plug the plug into a wall recepticle. The prong get crushed flat & needs to be pried apart. some prongs are one solid piece and cant be pried apart.
If the plug is bad ,you can buy a new screw connect plug at home depotor dollar stores that carry electrical.
home depot wants $3 or$ 4.00 for 1 replacement plug and the dollar stores sell them 2 for $1.00
the line cord may also be bad where it goes into the fan motor.
you can find out by wigeling the cord with the fan runnug and when you wiggle the bad spot the fan stops running.
Posted on Oct 12, 2013
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Posted on Sep 04, 2008
red54eyejp
  • 25 Answers
SOURCE: blade broke where to get new one
You can call by phone Lasko customer Service and Replacement Parts......1-800-233-0268.......givi them FAN info and they will ship you part..........................Also check, your product may be covered under WARRENTY or may be listed under product recall .......either will reduce your COST .....
Posted on May 11, 2009
  • 5 Answers
SOURCE: lasko fan
I can tell you how to take the fan blades off your Lasko Model 3723 fan, but you might not be able to use it on your other fan. The reason why is that the motors, although similar, may not have the same diameter shaft.
Of course, you should have the power cord unplugged from the AC outlet before removing the front fan grille and placing your hands on the blades. Safety first!
The fan blades and hub are a single unit that stretches to fit onto the motor shaft. There is no setscrew at all. Take any sort of metal bar or tool such as a screwdriver or pry bar and carefully lever the hub off the shaft by pressing your lever to lift the hub a small fraction of an inch on each side, working the hub slowly upwards against the long vertical bars that support the motor. If you have reasonably strong hands, you may be able to pull the hub toward you by placing your fingertips under the edge of the hub and pressing with your thumbs against the vertical support bars as needed. It's not too difficult to do.
Posted on Jun 11, 2009
  • 347 Answers
SOURCE: my lasko fan stopped working after a power outage.
check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
Posted on Aug 30, 2009
  • 15 Answers
SOURCE: Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Posted on Nov 09, 2009
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
My fan was working very well and all of a sudden it stops like it has a shock and when i moves the chord it starts back to work but now it just stop completely and is not workin for like a month now
Hi miahpurplean...
You have a broken electrical cord, it is probably broken inside of the fan.
Not too big of a problem...take fan apart, cut about 6 inches of the cord off from where it was attached to the fan and reattach the new wires that you exposed when you trim the plastic from the cord (about 1/4 inch).
Your fan should work again after this.
Please take time to rate me
Aug 12, 2011 | Lasko 1850 Stand (Pedestal) Fan
The fan moved really slow on any level and on my other fan it stopped working all together. help.
The one that is slowly turning take off the back cover and oil it in all the spots where the shaft goes through
Jul 21, 2011 | Lasko 1820 Stand (Pedestal) Fan
Hi suedevito,
Nov 08, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
My lasko fan stopped working after a power outage. the motor hums but blades dont spin
Aug 26, 2009 | Lasko 3135 Stand (Pedestal) Fan
Blade broke where to get new one
May 10, 2009 | Lasko 2506 16", 3 Speed, Oscillating Fan
Oscillating
Hi - You can download the manual by clicking the link underlined in blue below:
Lasko
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | Lasko 1820 Stand (Pedestal) Fan
Wiring
12,000-BTU Portable Air Conditioner with Manual ... 3135 30-Inch Oscillating Industrial-Grade Pedestal Fan ~ Lasko ... 42.62 : Soleus Air FCM-30 12-Inch Convertible Stand/Table Fan ...
Aug 25, 2008 | Lasko 1820 Stand (Pedestal) Fan
LASKO fan problem
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
Dryers Logo
47 people viewed this question
Top Dryers Experts
