Question about Acer TravelMate 290 Notebook
Acer TravelMate 290 PC Notebook not starting
Hi All, when I press start button the laptop starts as normal,the sound is also normal,but it hang after few second,nothing apears on the screen.The start ligt glow too.what i found abnormal was the cd drive light also glows when I start,I feel as if it is try to read CD which is not there in the drive and it hangs. I believe the CD light should not glow while starting. I tried the trick to remove battery and CD drive and put that back again couple of time and it started for me few time. I noted that the CD drive light was not glowing when it started. As for now that trick is not working. Can any one help on this problem. Thanks NAvsum
  • Anonymous Sep 30, 2007
    I tried removing memory makes no difference same symptoms remain. I more thing is Hard disk light also does not glow.
    Thanks for the help
  • 35 Answers
I believe these are BIOS indicators on some type of motherboards This could be a motherboard or memory problem. What happens if you remove some or all memory?
Posted on Sep 27, 2007
I just had the identical problem and solved it by moving the single memory module to the other slot.
Posted on Oct 08, 2007
SOURCE:
My laptop was hanged from last one hour how to start of samsang compeny
If I understand correctly; your laptop is hanging( hung in a loop ) and unable to function. I suggest a "Hard Shutdown". This will allow the computer to restart. Press and hold down the laptop's power button for approximately 15 seconds. The laptop should power off then press the power button normally and it will restart. Start up may take longer especially if you are using a Windows Operating System. The Operating System may detect that there was a problem and will attempt to correct. Simply follow the onscreen prompts. Good Luck.
May 12, 2014 | Computers & Internet
I press start on laptop, windows 7 will not load up, i have to press F8 a few times to load ,windows 7
Try a cold start, unplug, remove battery, hold down on/off button for 10 seconds, replace battery, plugin, push on/off button, try to start normally. If that fails do a system resotre/ recovery.
Nov 04, 2012 | HP Computers & Internet
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I when i turn on my acer 4150, apears the main logo from acer, but the keyb do not work, after a few seconds apears a black screen and starts a continuously beep, then i have to turn off becouse the noise
I have same problem before, it is because my laptop keyboard was stuck. Try to remove your laptop keyboard and turn the laptop without keyboard. If its run normally, you should replace your keyboard with a new one.
Jul 05, 2011 | Acer TravelMate 4150LCi Notebook
I do have a dell laptop, but last night it hangs up den i cannot turn it off already so i'd just let the battery empty, i recharge it wen i woke up in the morning den it says the computer was not shut down...
I second what computus suggested, but I believe you'll have to press F8 repeatedly during boot instead of ESC or Del button. Boot up in safe mode and it should be able to restore things :-)
Aug 13, 2010 | Dell Inspiron 1525 Notebook
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
No short cuts in my screen
are you able to operate your system after it is started. I mean open Windows Explorer ??? Mouse working ?? etc ??
if its only the desktop icons, then try this:
Right Click on Dekstop >> Arrange Icons By >> Show Desktop Icons
Feb 17, 2009 | Dell Computers & Internet
Laptop won't start
remove battery and check if is charged.
put back battery and connect power supply.
keep ON button pressed few seconds until it flashes.
if not started wait few second and try switching on normally.
if unsuccessfully check both power supply and battery with manufacturer
Jan 11, 2009 | Computers & Internet
Kitchenaid dishwasher will not start
sounds like theres something stuck in the drain pump.hope this helps.
Mar 05, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
IPHONE HANG UP
press the home keys and power button simultaneously for about 5 secs... it should reboot. :-)
Feb 02, 2008 | Apple iPhone Smartphone
Acer TravelMate 290 Notebook Logo
170 people viewed this question
Ekse
Alun Cox
