Question about Nordic Track NordicTrack T7 si Treadmill
The treadmill motor won't run. Everything else works. I can adjust the incline but when I try and get the belt to move by pushing the speed buttons, nothing happens. I have removed the motor cover and checked to make sure that all of the connections are tight and I can't find a problem there. Thank you for any help you can give.
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
bwinton
  • 83 Answers
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Posted on Apr 30, 2010
  • 218 Answers
SOURCE: My treadmill lights come on when i push a button
the motor controller is bad
Posted on Aug 11, 2010
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill won't start. Console works but when
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
11_21_2011_11_34_59_pm.gif11_21_2011_11_35_24_pm.gifRemember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
Posted on Nov 21, 2011
My trimline 2200 treadmill will not start the belt. I started having problems where it only worked on very slow speed now the belt won't turn at all. I tried pushing the circuit breaker reset
Likely your motor wore out, or that the circuit for the motor driver is shot. If the panel is starting it is likely that the motor is not getting any power at all.
Jan 21, 2015 | Exercise & Fitness
Tip
How to reset/recalibrate your treadmill after replacing drive or incline motor,...
Make sure you recalibrate your treadmill after installing ANY controller, motor or console. You can NOT over calibrate your treadmill. You want to make sure you adjust your pedometer for the correct operating speed and incline adjustment. First plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. The adjustment is made with a phillips screwdriver, and the adjustment point is on the motor controller. It is a little square metal box with a yellow plastic adjustment screw inside. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode. Double check that the treadmill is operating at the correct speed and incline motor works correctly, by running maximum settings. Once you are done, be sure your treadmill is properly protected from surges from power spikes that can destroy the work you just performed.
Hope this helped.
on Dec 08, 2011 | Nordic Track Exercise & Fitness
Incline does not work but incline motor runs for 3 to5 seconds proform415ct
if the motor tries to work but incline does not go up something is jammed on the treadmill or the incline motor is bad
Oct 17, 2014 | Proform 415 CT - Treadmills
Just got Nordictrack 1750. Assembly was easy but incline does not work. Everything else seems to be okay. Took motor cover off and do not seem to be getting any power to incline motor.
go HOOD cover motor follow the steps or ready your owner manual, and RUN the software calibration for easy diagnostic and fix it.
The
Steps for Newer Style Console Calibration
1. Locate the calibration area on the
rear or underside of the console (a hole, near the console\'s center, that goes
through to the electronics board. (This hole should not have a screw in
it.)
2. Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click when
pressed).
3. Press the button 2 times
(with the pencil eraser). The first click should show CL11 in the
console, the second click should show CL21.
4. If the process was done correctly,
and CL21 appears in the console, you are in "calibration mode."
The next few steps consists of pressing buttons on the console
and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in
the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in
7. Press ENTER. CL24 should display in
8. Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should
display in the TIME window. You should then see the letter
"E."
10.
Press
ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be
off, the treadmill.
12.
Push
the ENTER button. The walking belt should start to move, accelerate to maximum
speed, then stop on its own.
13.
When
the belt stops, the incline should self test by raising to its
highest incline position, then lowering back down to its lowest position.
14.
Once
the incline test is complete, push the POWER button 2 times. The unit should
shut off and the console should go completely blank. If this
happens, the treadmill is done calibrating and is ready for use.
If the letter
"F" appears in the SPEED or INCLINE window when the power button is
pressed 2 times, the treadmill is indicating a failure somewhere
either in the SPEED or INCLINE (depending on the window the
"F" appeared in). Troubleshooting the failure would be the next
step.
God bless you
Oct 17, 2013 | Nordic Track Exercise & Fitness
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
Motor runs all the time
test the speed sensor, with DVOM, for open or faulty. clean it, adjust it see the diagram , and tigh very well the connector. RUN the software calibration for troubleshooting, and fix it. God bless you
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 27, 2013 | Proform 730 Folding Treadmill Model...
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
5600t speed adjust does not work
RUN the software calibration, for troubleshooting and fix it.
See the steps for calibration.
God bless you
Jan 09, 2013 | Keys Fitness 5600T Treadmill Drive Motor
Tempo 621T treadmill stuck in incline postion scale is reading 0 but it is not completely down..How to reset my incline button
Run the software calibration for troubleshooting and fix it. See the next steps. God bless you
Lube the elevation motor, shaft and gear. adjust the POTentiomer,
Jan 09, 2013 | Exercise & Fitness
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
Nordic Track NordicTrack T7 si Treadmill Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
