Question about Pantech P9070 burst
My phone refuses to charge and sometimes while it's on the charger, it says that it's charging but the percentage is going down.
2 Suggested Answers
  • 4 Answers
SOURCE: Battery will not charge
Through this in to gabbage
Posted on May 30, 2008
I have an iphone 5s and it won't charge.It would only charge with some chargers. Also the battery percentage would go down then back up.
that seems to be the way the chargers work . leave it on till the phone tells you it is fully charged .
Oct 04, 2015 | Apple iPhone 5S
My htc one mini isn't turning on, But it comes up with the battery sign? What's wrong with the phone?
It sounds like you need to charge it up.the charge icon usually means there is insuffient power to switch on.it may be the battery isn't charging properly I.e. The charger is faulty...the charging point is faulty...or the battery is no longer holding a charge.sometimes if you charge abroad or on say a ship where the amp of the circuit is less the 500 mah the charging behavior changes and it takes a few attempts to get it to behave normally.
another thing you might try is change the charger to a more powerful one just to give it a boost.i.e. Instead of using the normal 5 volt 1amp try a charger with 5volt 2 amps.once the battery reaches at least 5%. It should start up.fully charge and then try to get into the habit of running phone down to 20% and up to 80. % instead of continuously charging each day when the phone is still holding a healthy percentage?only once in while should you run below 5% and then charge to 100% .incidentally most batteries start to lose their stamina after 500 plus charges.
Feb 05, 2015 | HTC Cell Phones
Battery on G-zone Commando Losing charge even though it shows it is charging
A charger can indicate it is working but if it is trying to charge a dead battery you will get the result you describe.
Mar 09, 2014 | Casio G-zone Commando
Lg thrill wont charge
Date: May 16, 2014
I have an LG Thrill 4G. My phone just went thru an issue where it wouldn't charge past 4%. Sometimes, it wouldn't go past 2%, so I had to leave it on the charger ALL the time - or risk it dying, completely.
For days, the only services shown on my battery usage were:
Cell Standby: 33%
Bluetooth: 33%
Phone Idle: 32%
Display: 2%
I replaced the battery with a brand new one - NOTHING changed. Battery still sat around 2-4% for the entire day, while on the charger. So, I started uninstalling apps like crazy - just to see what would happen.
NOTHING. Same thing.
So, I decided to at least install the Facebook app back...and the upgraded version had to be installed - so I did it.
VOILA!!! My phone instantly started charging ...8%...14%...24%...52%...80%...91%...all over a period of about an hour. Just a constant charge going up a few percentage points every few minutes...
...and all of a sudden, started going back down pretty rapidly when it hit 92%. Within maybe 3mins, the charge went from 92% to 78% - and I wasn't using the phone. I was just watching the meter drop 2 percentage points over a period of a few seconds, each time. I decided to quickly turn the phone off at 78% but left it on the charger.
After roughly 5mins, I turned the phone back on, just to see what the charge would be sitting at. WOULDN'T YA KNOW - 3%.
How can battery life go from 78% to 3% - while it's OFF - within a 5min span??? Therefore, my question is: was it really charged to 78% when I turned the phone off? Or was the battery meter being "tricked" by some app that might be installed?
The first battery it did this to was the 1500mah. Used that battery for like 3 days of this before I replaced it. The battery the scenario above JUST happened to is my new 3500mah battery, and it's been giving this 3500mah battery the 3% capacity for a whole day and a half now...
Mar 29, 2013 | LG Thrill 4G
My zte merit wont charge
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Feb 06, 2013 | Cell Phones
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
My LG VU charges just fine sometimes, and other times it will say its charging and drain the battery, and other times it wont register that its charging at all.I have 2 house chargers, and one car charger...
well about the arrows being upside down, some phones like this one the charger goes in up side down like for example the katanas. But about the charging issue check in the back of the phone and look for a red or white sticker or maybe pink. if its red then thats indicating that it has been water damaged and if its white then that indicates that if might not be but if you look in the charge port and check if it has like some green and white corosion in it. If you would like some help with this just e-mail me at Purelatina2004@yahoo.com
Jun 15, 2009 | LG Vu CU920 Cellular Phone
Pantech P9070 burst Logo
Top Pantech Cell Phones Experts
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
