Question about Frigidaire PLMV169DC Microwave Oven
My work light/night light work, but will not turn off. No matter which button you press, either both will light up or one turns off, but you cannot turn all of the lights off. Seems like a control board issue, but which one do I need?
    Scholar:
  • 178 Answers
This sounds like an IC problem on the board. They typically use IC's to switch the lamps on and off. Sometimes the IC's short out and stay closed. I saw this problem a lot on another make in the past.
Posted on Oct 28, 2013
2 Suggested Answers
  • 43 Answers
SOURCE: Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Posted on Jan 28, 2008
My Advantium 120 microwave shows the time, but none of the buttons respond to being pressed.
Try turning it off at the power switch,leave off for several seconds then switch it back on, it may reset the control unit, if not take it to a repair outlet,
May 27, 2015 | In Microwave Ovens
Cooking light does not turn off
We see and repair this a lot. The problem is on the controller assembly.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes.
Apr 14, 2013 | Panasonic NN-H275 Microwave Oven
Microwave Cooktop / Night Light not working
I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
Mar 06, 2012 | GE Microwave Ovens
Night Light
Replace the touch panel. One or more buttons are failing.
Feb 03, 2009 | Frigidaire PLMV168 Microwave Oven
Night Light
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
46 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
