Question about Kitchen Ranges
I need a wiring diagram for a kelvinator stove model: kc600bs electric oven the selector switch the long brown one
SOURCE: need color code/wiring diagram info for Enterprise electric range installation of thermostat
I need the Oven knob for the front panel. The numbers have rubbed off on mine. Thanks, in advance, for your help!
Posted on Jul 28, 2008
  • 250 Answers
SOURCE: schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Posted on Jan 20, 2009
beachin
  • 6 Answers
SOURCE: GE Profile Electric Stove - Buttons for oven don't work
We had a bunch of storms roll through the area and we figured a surge must have fried our control panel. We decided to buy a new oven rather than spend $200 fixing this one. Luckily, our local Sears rep wasn't in it just for the commission and suggested we flip the circuit breaker off for 10 minutes to allow the range to reset itself. Works good as new! So, try this first before you make a decision. Good luck!
Posted on Apr 03, 2009
Bat1956
  • 585 Answers
SOURCE: I have an older model brown stove and cannot light the oven pilot
The oven pilot is accessible through the broiler door, (you're pretty much laying on the floor to light it) or through the oven bu removing the oven bottom panel. To remove the oven bottom, place fingers in holes near the door, and apply pressure to slide the bottom toward the rear, and lift when the front (by your fingers) comes free. Remove completely and set aside. You should now see a flame spreader (V-shaped metal pan) retained by one or two winged screws. Removing the screws allows removal of the spreader. This exposes the burner, complete with pilot. There is two tubing lines to the pilot assembly, one about 1/4 inch dia. and one much smaller. the one at the end of the 1/4 inch tube is the pilot. The piece at the end of the really thin tube is the thermocouple. You have to heat the thermocouple to get the gas to come on to the pilot. A match just won't do it as you need to apply a flame to the thermocouple for about 30 seconds or so. Heat the thermocouple until the pilot will self-sustain. When the pilot stays on on it's own, put it all back together. If you elect to just go through the broiler, again heat the thermocouple until the pilot will self-sustian.
Posted on May 07, 2009
SOURCE: Electric Diagram for Kenmore Model 790
I have a Kenmore Model 790.91062601 and it has stop heating. None of the burners or the oven will heat. Any solutions
Posted on Aug 30, 2009
Where is the fuse location for Kelvinator wall oven model # R30-1
Kelvinator Oven Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/electrolux-kelvinator/oven/
How to light an oven of kelvinator KCL86GSC gas co. Kelvinator ... Replacing thefuses on my kelvinator stove model H
Nov 15, 2015 | Ovens
Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
Request the wiring diagram directly from Kelvinator.
Jun 25, 2014 | Ovens
Ariston stove wiring cx 67s p6 x ng
When you replaced the burnt out selector did you notice any other damage? The selector switch may be connected to the energy input control. Most circuits have some sort of control, allowing only the right amount of energy to be put in. If this got damaged, the fuse would be inconsistent.
Elisa Jed ' http://www.atlasappliances.com
Jun 22, 2014 | Stoves 720EF Electric Double Oven
Wiring diagram stove
That is an older model, so the wiring diagram will be harder to find. Have you already checked the manual? I would also suggest checking online at the manufacturer's website. Other than that, you can try online.
Jun 22, 2014 | Ovens
Kelvinator stove MODEL KC600BS
can i get a wiring diagram for kelvinator oven switch kc600bs
Oct 11, 2013 | Stoves Ovens
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Schematic wiring diagram
parsonm
Oct 30, 2008 | Stoves 720EF Electric Double Oven
Kitchen Ranges Logo
251 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
