Question about Epson Stylus CX5400 All-In-One InkJet Printer
Feed 1 paper at a tym
Any help on my printer that every tym i print it will eat the whole amount of paper to paper feeder and cause paper jam. the problem is when i print many pages i have to sit down infront of printer and feed 1 paper at a tym just to avoid the eating the whole amount of paper. any solution plsssssss.
    Problem Solver:
  • 6 Answers
Try freeing up the paper before you insert it into the printer. an easy way to do this so to "fan" the paper by holding one end and letting each paper on the other end be released one by one.
another thing is that you may be inserting the paper too much inside the paper tray. try inserting the paper slowly and stop at the first slightest notch you feel
Posted on Apr 23, 2009
Printer cant take the whole paper
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Aug 29, 2011 | Lexmark Color JetPrinter Z23 InkJet
I can't get the paper feed to work properly. Printer is telling me to load paper when it is full of paper Printer is asking me to clear paper jam when there is no paper jam Printer is just not...
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
My pinter is an X4270. It prints well, but will not feed the paper to fax, scan or copy. I keep getting a clear paper jam reading, but there is no paper jam.
Aug 07, 2011 | Lexmark X4270 All-In-One InkJet Printer
Paper get stuck every time I try to print. I notice the paper just slides a bit inside and then on right side it just gets collected and I have to turn printer off to clear paper jam. please help. thanks.
Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
2. Grab a flashlight and look inside for any debris.
4. If feeder is clear, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
Apr 28, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have a minolta copier (Di1610fp). The feeder does not work. When a paper goes through half, it stops
Try cleaning the media rollers with 409 solution. The media feed rollers become dirty after a certain amount of prints. The toner is a wax based toner so excess wax gets on them after a while. Dirty media feed rollers can also cause image shifting problems. I hope this helps you.
Apr 15, 2011 | Konica Minolta Minolta DI1610P Printer,...
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
I865 flashing 3 times
That's a "paper jam" error that can be fixed by removing all paper and pressing the resume/cancel button. Then replace the paper in the feed chute.
The printer can straighten out a crooked feed to a very limited degree. The photo feeder attachment can interfere with a really full 8x11 feed. The i860 is very susceptible to overfilling the 8 1/2 x11 feeder without notice until you try to print. I usually remove the photo feeder until I need to print photos, and keep the regular paper feeder no more than 3/4 full. I pull out the regular paper when printing photos.
Feb 24, 2009 | Canon i860 InkJet Photo Printer
Printer Feeder not working well. Paper always gets stuck.
Recurring paper jams can be caused by broken parts, using too much paper in the in-tray, or parts (usually the rear door) not on all the way. This video explains how to fix a paper or carriage jam, but explains along the way the things to watch for. If you go through the steps in this video and you still get paper jammed, you may have a broken printer that needs to be replaced or repaired.
Feb 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper jam epson stylus 5400
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 08, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
93 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
