Question about Garmin zumo 550 GPS Receiver
450 cradle power
The cradle stop powering the zumo 450. How can I fix it?
SOURCE: power supply to garmin zumo 450
When I installed the Garmin cradle for my Zumo 450 on my bike I installed the power cable directly to the Main line going into my headlight.I then ran the cable out of the back of the headlight and hid it behind my windshield and then, out through the handle bars up to the cradle, you can barely see it. Works great for me!
Hope this helped,
DTL
Posted on Feb 27, 2008
marcelbakker
  • 174 Answers
SOURCE: my zumo won't power on
This sometimes happens if the cradle is owered while you connect the zumo...i guess it hits some wrong contacts first and goes bonkers. I'd advise th zumo users to pack a small allen screw bit to unscrew the battery, just in case it freezes or blacks out again....better safe than lost in the middle of nowhere!
Posted on Oct 27, 2008
mattballew
  • 89 Answers
SOURCE: Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Posted on Nov 24, 2008
SOURCE: garmin zumo switch on problem
Use the allen wrench to remove the battery. Let stand for 5 minutes and replace the battery. It should start fine. Mine has done this 3 times since I purchased it.
Posted on Jan 30, 2009
  • 1196 Answers
SOURCE: my zumo 450 on my
I will suggest you reset your GPS, to reset your gps, follow this steps, turn off your device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press Yes to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 to 30 minutes in order for it to requires fix to GPS satellites. with this, the problem should be rectify.
Posted on Apr 21, 2011
Garmin 550t. When i have my zumo on my motorcycle mount it seems not to take power from the bike & then after a while it tells me "low battery", it is wired directly to the bike battery so it should...
Moisture has probably gotten inside the motorcylce cradle through the connector pins. if you take it apart, there is a very small ribbon cable that attaches from the pins to the cicuit board. if moisture gets on the end of the ribbon cable it can short out the small power tracers on the cable and cuircuit board. this happened to me. i had to buy a new cradle. 85.00
May 16, 2010 | Garmin zumo 550 GPS Receiver
Speaker doesn't work when using Garmin on my motorcycle but it works in my truck. got any ideas?
there is a speaker on the cradle for the car and none on the bike cradle probably due to the exposure to the elements when on the bike and i think the Zumo must be powered from the bike for the speaker on the Zumo to work when riding.
May 23, 2009 | Garmin zumo 550 GPS Receiver
GPS is not getting power on the motorcyclen mount.
If you're sure the power cord is getting power, then the mount has likely failed. Mine has failed 3 times. Replacing the mount will fix the problem as it did on mine. If the unit is less than 1 year from purchase, Garmin will warranty replace it for free. If not, it'll cost you about $85 plus shipping to put a new one on.
May 09, 2009 | Garmin zumo 550 GPS Receiver
The garmin is on but frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Mar 27, 2009 | Garmin zumo 450 GPS Receiver
Garmin Zumo 450 will not turn on
try removing the battery withthe included allen key, press the power button to drain all the power inside the system and reinstall the battery and then try it.
Jan 11, 2009 | Garmin zumo 450 GPS Receiver
Garmin zumo switch on problem
Jan 05, 2009 | Garmin zumo 550 GPS Receiver
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
My zumo won't power on
Aug 16, 2008 | Garmin zumo 550 GPS Receiver
Zumo won't power from either cradle
Connector block at the base is stuffed. Needs to be replaced.
Aug 15, 2008 | Garmin zumo 550 GPS Receiver
Power supply to garmin zumo 450
Hope this helped,
DTL
Feb 25, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
16 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
