Question about Garden
The 3 piece pipe in my Midas Lin water fountain is broken. The bottom part that screws into metal and connects to the pump is broken. Model c893-71 is the model #. Can someone tell me where I can obtain a replacememt pipe?
  • EDDIE TAYLOR
    EDDIE TAYLOR Oct 13, 2013
    The pipe is plactic tnat leads from the pump to the top of the fountain.
  • David Perkins
    David Perkins Nov 17, 2013
    Eddie. Did you ever find the part you were looking for. I have the exact same model with the same broken part. I'd like to know if you were able to resolve your issue. Thanks. David
4 Suggested Answers
redbeard00
  • 957 Answers
SOURCE: water fountaian will not work
The curcuit should be simple. The pump is the heart or this system it draws water to the pump(if it can't then the hose is plugged, or damaged) or the pump is bad. If the pump is working then it should be pushing water to its destination. if the water comes out the pump but wont or cant push the water to its destination then the impeller is bad.
Posted on Apr 26, 2009
  • 990 Answers
SOURCE: Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
Posted on Jul 07, 2010
  • 3 Answers
SOURCE: Where can I buy a
Not sure about that model but I had a problem with my fountain light adapter and I contacted the maker of my fountain (BOND MFG). They want $20 for an adapter and $10.50 for shipping. Here was the contact info I used: csr1@bondmfg.com or www.bondmfg.com Hope this helps.
Posted on Jul 31, 2011
Tube going into back of ice maker leaking and won't stay in place
Go to Lowes, Home Depot or other hardware store... purchase a Grab-It screw extractor (very inexpensive and a great addition to any toolbox!) Start with the SMALLEST of the 3 extractors and remove the broken metal as if it were a nail or screw that has a broken or stripped head. NOTE! Be sure to read and follow the Grab-It instructions regarding the forward/reverse for the drill!
Mar 17, 2014 | Amana ABB1927DE Bottom Freezer...
How do I take apart model PES-80-PW
nothing to take apart on this one it's a mag drive pump , if somehow the housing requires cleaning , backflushing down the outlet pipe is about the only way to do it , unit is sealed otherwise
mag drive means that a magnet is used to couple pump to motor so a direct connection is not needed so no drive shaft seals to fail , mag drives should never never be run dry with low to no water in pond , they use the water for cooling and will fail beyond repair if allowed to melt
Mar 31, 2013 | Little Giant Submersible Fountain Pump
I have a 2hp sprinkler pump that I am having trouble priming. I have 2 check valves on in the water by the intake and the other by the pump. It has take a few hours to get the water to the pump but still...
1. You only should have one check valve; the one in the water is best, remove the other if you can.
2. Make sure there are no leaks in any of the piping between the water and the pump inlet.
3. Take the pump apart, thoroughly clean the new seal, the two halves of the pump that go under the metal band, the inside of the metal band.
4. Lubricate the new seal, the outer sides of the pump halves where the metal band squeezes together, the inside of the metal band where it contacts the halves and even the screw on the tightening device using petroleum jelly (Vaseline) or equal. Make sure the pump literature does not recommend against whatever you use.
5. Reassemble.
6. Fill the pump with water, open the discharge on top of the pump if possible and prime.
Normally, a pump, even with a long run will prime in 5 minutes or less.
Write back.
Your FixYa Texpert,
Gary
Aug 22, 2011 | Flotec Corrosion Resistant Convertible Jet...
My intex sand filter is shooting sand into the pool
You have a broken "lateral". You will have to remove the sand from the filter, find and replace the broken lateral (pipe with slots in it in the bottom of the filter). When you are ready to refill the sand, put enough water in the filter to cover the laterals (several inches actually) to avoid damaging them as you fill.
Thanks for allowing me to assist you this evening @ FixYa.com
Jun 22, 2011 | INTEX Sand Filter Pump
Behind the water pump it leaks antifreze its not the water pump but the hose from the radiator hook up to this metal tube and goes to the water pump that join is leaking does it have a gasket in between or...
you talking about water pump bypass heater pipe the metal elbow piece to the water pump hosing.the metal elbow piece is held in place by small bolt or bolts you should have either gasket or o ring betwween where metal elbow mounts to water pump housing.replace the hoses also.some times the hose will be leaking not gasket or o ring at the metal elbow.make sure screw or screws not loose or missing to the metal elbow pipe.
Apr 17, 2011 | 1997 Geo Metro
I bought a pump for my fountain 4 months ago, it stopped working
This sounds like you should check your suction pipeing again and with fish be sure to get a screen for it. Then also check the impeller on the pump to be sure nothing inside it. You will need to open the pump to do this. If it has been working their is probally nothing wrong with the pump itself.
Dec 14, 2009 | Aqua Garden
Briggs and Stratton 20hp twin cylinder runs only with full choke
Had one on my saw mill had this problem as well Try pulling bowl off bottom of carby as the float can get **** with old fuel especially ethanol fuels as they attract water bowl is normally held on with one center screw on bottom of carby. Note always turn fuel off and let engine run out of fuel as this stops goop from building up in carby
Sep 04, 2009 | Briggs & Stratton Briggs Stratton Intek V...
The shower just give off piping hot water
Is it hooked up to a hot water line? Change it to a cold line.
Jul 05, 2009 | Henri Studios Henri Studio Summer Showers...
1999 kia sephia leaking antifreeze
you will need to replace that water lin it runs to the water pump which is why its leaking so badly....you will need to replace it asap
Jan 19, 2009 | 1999 Kia Sephia
Return hose on back of water pump leaking badly. Does this hose screw in or is it pressed in and will i need to buy a new housing to replace??
The water pump is a 2 piece deal; the metal return pipe has an O-ring that fits tight into the back side of the pump.
Aug 14, 2008 | 1997 Toyota Paseo
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
