Question about Empire ECS DV-55E Mid-Size Heater
How do i turn it on to get heat, the knob is on "on" I have never used a gas heater in my life.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
First is the pilot light on if not you have to get it on first
If you can't do that then I suggest getting a friend or someone that can show you
Not knowing the type of stove it is impossible to help you and even if I knew getting you enough knowledge on here would not be easy
See if you can find a name and model number then do a search on the mfg website for a owners manual
Posted on Oct 20, 2013
How do you light the pilot
Turn the gas knob to the pilot setting, press it in and hold it. You should hear gas escaping while in this position. Do not let more than about 10 seconds of gas out at one time as it may pool. Light the pilot while holding the gas knob down for a minute. Release the gas knob (the pilot flame should stay lit) and turn it to the ON position. To make sure the gas heater is working properly, turn up the thermostat and see if the heater heats up. How To Light The Pilot Light On Gas Heater
Oct 19, 2016 | Heating & Cooling
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
2006 water heater. Is it only run on gas. How do i turn it on.
If it is a regular gas hot water heater You need to turn the knob on the gas valve to pilot. Depress and hold the knob down. while doing that press the green button on the side of the valve . you may have to repeat that a few times. that button makes a spark to light the pilot. You need to hold the knob down for about a minute more to let the thermocouple heat up and signal the gas valve that it has a flame. release the knob . if the pilot flame stays on ,turn the knob back to the on position. If that does not work repeat if still not working give more info. Make and model of heater
Feb 03, 2015 | Water Water Heaters
Kozy world propane wall heater pilot will not light
This can be caused by several things:
1. The inline gas valve running to the the heater is OFF. Turn the valve ON.
2. The gas control knob on the heater is not exactly in the PILOT position. Unless the knob bottoms
out and you feel strong pressure (other than spring pressure) pushing back at you. It's not exactly
in the PILOT Position. Once the pilot lights, hold the control knob in for 30 seconds to 60 seconds
to allow the Thermocouple to full heat.
3. The pilot is dirty and needs to be cleaned, as do the burners.*
4. The LP Gas Tank is empty or to low to maintain te proper gas pressure.
* Here is a link to a demonstration on how to properly clean the pilot & burners.
http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | The Companion Group Kozy World Portable...
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
How di i light the pilot light
Be sure that the gas line to the heater is ON.
Looking at the Control Knob on top of the heater, you note that he knob has 3- positions: OFF, Pilot, ON.
Turn the control knob to the Pilot position and push down on it. If it does not go all the way in and your do not feel strong pressure pushing back at you, it is not directly in the pilot position. (Reposition the knob slightly and try again). Once You're sure the knob is directly in the pilot position and the knob is depressed, continue to hold it in and press the Ignitor button next to it. You will hear a loud click. If possible, watch the pilot assembly inside the heater when you do this. That way you can see if the pilot lit the first time. If not repeat, pushing the ignitor.
If the gas line had been turned off to the heater, the pilot may not light the first couple of tries, due to air being in the gas line. If that is the case, hold the control knob in until you smell gas, let off, wait 5 minutes and repeat the lighting sequence.
Once the pilot does light, continue to hold the control knob in for 1 minute. This will allow the Thermocouple to heat up completely. Ease off the control knob and the pilot should remain lit. If it does, turn the control knob to ON and the burner will light.
Now you're ready to set the temperature or comfort level. You do this by raising or lowering the flame height. The higher the flames, the more heat it puts out. The lower the flames, the less heat it puts out. The stripe on the knob represents the flame heights - Narrow stripe, lowest setting, widest strip, highest setting. Or your specific model may simply say Low, Medium, High.
If you do not have the Owners Manual for this heater go to http://www.desatech.com/
click on Wall Heaters and enter the Model Number of your heater. You can then download and print the Owners Manual.
Hope this helped to get you up and runnig.
Feb 20, 2011 | Vanguard International Blue Flame - Large...
Weber Genesis Gas Grill won't heat up very high
yes the control knobs are what controls the heat, its a saftey thing on the bbq so turn off tank undo gas from tank open knobs release gas from line , turn off control knobs , reconnect gas line to tank ,turn on slowly , turn control knobs to on and light,
Jul 05, 2010 | Weber Genesis Silver B Grill
Blower but no heat, no gas or no pilot ignition?
The pilot has to be lit.And to do so turn the knob to pilot.Then press it down and gas will come threw the pilot,then light the pilot,and hold the button down for about 45 seconds,count slow.The pilot has to heat the thermocouple up before the pilot light will stay on.Once it stays lit,turn the knob to on.
Oct 20, 2009 | Heating & Cooling
How do i light a Reddy Heater rcp 2000 lp gas heater?
hold down the pilot valve knob and turn the arrow to pilot position push down on red button to allow gas thru pilot tube hold down and light keep button held down for 1-2 mins while pilot is on to heat up the thermocoulple then release and turn knob to on position.
Sep 12, 2009 | Reddy Heater RLP100 Portable Forced Air...
Pilot light goes out every time heater reaches & missing knob
the thermo couple thing that pilot heats up is not staying in flame if knob is broke you may be able to heatup manualy to get gas valve to open some will wome wont
Jun 10, 2009 | Heating & Cooling
Empire ECS DV-55E Mid-Size Heater Logo
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
