Cpier Rizo EZ 390U P-94 -225 - Office Equipment & Supplies
How do i Factory reset lg rizo 8062 Android
Hold the Power button and the Volume Up button for 20 seconds and follow onscreen prompts.
Feb 24, 2016 | LG Cell Phones
Rizo ez200E p12-309
Error type P12: System ErrorError point 309: Master-compression-motor encoder sensor count did not change as the master compression motor activated in the compress direction and moved out from the home position.
Try this: Press reset-key. If recovery fails you machine needs service.
Sep 19, 2012 | Riso RZ220 Duplicator
Ic regulator of model: 14PT332/00
This is device that control output voltage for digital circuits, audio, etc is very importante, otherwise this circuit of tv or any device electronic the function had not stabilize, creating spike, rizo, or glitching in the circuit producing NOISE.
God bless you
Jul 18, 2012 | Televison & Video
Riso kz30 error code a34
j ai un rizo kz30 aui ne marche il signale une feux orange n 4
Jun 20, 2012 | Office Equipment & Supplies
Used toner bottle -1 is full, ? Where is this bottle located in this copier
That all depends on what make and model of copier you have???? There all different... You may be able to open the front door & there may be a picture of how to replace the toner... Good Luck
May 29, 2012 | Office Equipment & Supplies
Riso 390U error code p19 208 .... doesnt seem to be loading the master roll correctly, any suggestions?
Error P19-208
Error type P19: Thermal-pressure motor lock Error point 208: TPH pressure sensor does not go ON within 2 seconds after the thermal-pressure motor activates in the decompressing direction.
Hints: Check mentioned sensor. Check mentioned motor.
Jan 06, 2011 | Riso RZ220 Duplicator
We have a Rizo 220 ui with an error message
The rear cover may be off. Or you may have a bad cover switch.There are two switches at the top of the back coverone on the left and one on the right. Hope this helps.
Jul 14, 2010 | Riso RZ220 Duplicator
Error code d-17 in rizo rz 200ep
remove master from the drum and reset the master in the master making unit
Nov 30, 2009 | Riso RZ220 Duplicator
My rizo 220 wich cannot pull a muaster roll
Normally when this model does not feed the master,there is a drive band jump off it place n the master drive unit.To correct this open the front panel of the master making unit and check that all the drive bands is in place.I am working 10 years with Riso and this machines is the best I ever worked with.
Nov 26, 2009 | Riso RZ220 Duplicator
134 people viewed this question
k24674
