Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Transmission shifter hung up in netural - John Deere 420,1020,2010,2020,2510,2520 Tractor Float
  • 51 Answers
Expose the shifter mechanism from the base, look to see it the is an obstruction that is causing the shifter not to shift... Pay attention to the shifter mechanism ends and see if it's worn out, they sell both OEM and aftermarket shifter arms and linkages..
Posted on Nov 18, 2013
I change motor&trans together when finished the trans. has no revers or netural
When you changed the motor and transmission, did you use the gearshift control assembly that came with the motor and transmission that you installed?
Or did you do an exact match-up of motor for motor / transmission for transmission and re-use the original gearshift control assembly?
Predicated that the transmission is used, like from a junk yard and had been sitting, it may be defective; or it's just a matter of readjusting the cables from the shifter control assembly to the crossover cables to the gear shift selector at the transmission.
That model production year included a 5-speed manual w/OD transmission; 3-speed automatic; and a 4 speed auto w/OD.
If you don't mind me asking what did you remove from the car?...and what did you replace it with?
Mar 13, 2015 | 1993 Dodge Shadow
Where i s the netural safety switch on a 2001 Cadillac deville DHS? ?
It should be located under gear shifter if it's bad car will usually start in netural I will post a diagram when I have time hope thi
Dec 17, 2014 | 2001 Cadillac DeVille
New 1969 c4 auto transmission has park but no reverse or netural
Is it possible the transmission was not made for a Mustang ?
With the shifter on the floor, the linkage would be different than a car with the shifter on the column.
Have you contacted the company ?
Aug 25, 2012 | Ford Cars & Trucks
My gear lever takes more time to go back too its regular position when i put it in 2nd gear then any other gear. If i'mshifting fast it wont go into 3rd.
Check for slop in the shifter linkage. First to second is the longest throw. If you have to adjust it take slack out in netural. Thin test shift and check the netural light. Each time you adjust the linkage.
Feb 08, 2011 | 2005 Honda VT 750 DC Shadow Spirit
My neighbor has a 1984 toyota w cylinder with a manual tranny and it wont come out of reverse how do i fix this problem
try moving the shifter with the engin not running. if the shifter is still stuck try bleeding the clutch. If the doesn't help and the clutch system is in good working condition then the transmission is hung up between two gears. Remove the shifter cover and with a flat screw driver move the detemts to the nuetral position
Mar 21, 2010 | 1990 Toyota Pickup
I replaced transmission and now car dont start
Test the neutral switch.
Foot on brake
MOVE SHIFTER BACK FROM PARK AND NEUTRAL 10-20 times. This will re-new the metal contacts.
Shift to netural "N"
Start engine
Put lever back to Park "P" to warm up the truck.
If it start from neutral and not park then you will need a neutral safety switch.
Please rate my answer if it's helpful to you.
Cheers,
MUSTGO
Dec 14, 2009 | 1998 Cadillac Catera
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
54 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
