Magnavox 22ms855r Observation system, what cameras go with it? What kind of cables go?
3 Suggested Answers
SOURCE: I have a philips magnavox observation system model 22ms605r with 1 camera - 68mc305r. It can have up to 4 cameras. Are there any other cameras that are compatable?
i have 2 camera's for your system. email me at bzirbel531@gmail.com if you'd like to purchase them
Posted on Nov 29, 2012
SOURCE: I need a cord I need for an observation cam from magnavox
I'm having a similar issue with my Magnavox camera of the same model. I think I have a power issue. Correct me if I'm wrong, at least one of the lights on the front lens side of the camera (camera lens facing you) should be lit when there's power, correct?
Posted on Dec 16, 2015
How do I pair up cameras when 4 out of 8 go out
NEED TO CHECK THE POWER SUPPLY THAT FEEDS THOSE FOUR CAMMERA'S
Nov 12, 2014 | Lorex Sg19ld804161 19 Inch Lcd Observation...
CHANNEL SELECTOR MAGNAVOX 27TS73 C102
I am assuming that your cable is directly connected to the rear of the Magnavox C102 and you are not using any Cable Receiver or Decoder.
If that is how your system is hooked up, then what needs to be done is to enter your menu/setup and select CABLE instead of AIR or STD. Thereafter, channels maybe scanned and saved to the memory.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Televison & Video
Why does neither the co-axial cable from my DVR Cable box nor the one from my TV fit into the coaxial plug on the Magnavox ZV427MG9 DVD Recorder/VCR Combo ?
Check the coaxial cable connector type. There are two kinds--one that look like the RCA connector that you can just push in.
The other kind has a nut that you have tighten over the coaxial cable connector on the DVD recorder.
Dec 05, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
WHEN I PLUG IN MY CHARGER TO MY PHONE IT SHOWS THE BATTERY IS CHARGING BUT WHEN I TURN IT ON IT SHUTS OFF AND SHOWS THE WORDS VERIZON WIRELESS. PLEASE HELP ME SOLVE THIS PROBLEM.
First perform an observation of the pwoer charing devcie components. For example, observe the batterie as intact, the cover cases as least compromising the integrity of bateries. Also observe the power charging cables to ascertain that malfunctions are least available disallows full repower charging. Once the observation pahse has been accomplised least attaining any visible malfuncions, re-power charge the device in which instance allow to attain full or extensive power replenishment. Also, at which accomplishment phase, device that least fucntion would require new battery to replace the old. Attain an observation of the feasibility check s on the whole process of reviving the malfunction compared to acquiring a new product. perform compare and contrast prices on the marlket of parts oto resolving the device versus acquring another functioning device.
Feb 14, 2011 | Cameras
Hi, i own a bosch eazeo observation system however i do not have a dvr for the system. will the bosch dvra1081 dvr work with my observation system?
Hi, most certainly it will.
There should be a VCR DIN attachment at the back, and monitors hould have been installed or delivered with a cable for this din connection to get several video in and out to BNC bajonet, and audio out for plugging to the bosch recorder.
I have several used or new of this dvr´s or cable´s if youre interrested.
Dec 06, 2010 | Bosch DVR1A1081 Video Recorder
Strange, I have the opposite problem, I have the cord and camera, but no monitor. I found the following fix below to make this camera hook up to any tv or monitor, but it's greek to me. It may help you though! Or, if you can translate these instructions for me to hook up mine, I'l happily GIVE you my cord!
"The DC power was sent up the coax and the video is AC coupled and sent back down. If you open the
camera and trace the wire from the center pin of the UHF connector, it will lead to an inductor
and a large value capacitor. The video is coupled through the capacitor, which blocked the DC
power from the video output amp. The inductor (coil) blocks the video from getting back into the
power section.
Cut the inductor loose from the center wire of the connector. Put well filtered +12 VDC at 500
mA (1/2 amp) or greater into the inductor at this point while running a video cable from the jack
to a video monitor or to the video input of your home VCR. Then you can see the video on your TV.
Power return is to the ground of the connector or any other convenient grounding node.
Jan 28, 2009 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
