Question about LG 4.2 Cu. Ft. All-In-One Steam Washer and Dryer - White
DRYER GIVES FOUL BURNED SCENT
WHEN THE DRYER IS ON IT SMELLS OF BURN ELECTRICAL
  • 113 Answers
Unplug and check where the cord is screwed in at the back to see if any loose connections
Posted on Apr 23, 2009
Fez831cas3 dryer - keeps throwing breaker - shot sparks out the upper left side of unit, this is stacked washer dryer on top. If you have any ideas, where to get manual etc thank you - Colin
Hi. Heating element from the drier is burned and shorted to ground. DONT plug it back you may ignite fire and burn electrical installation
Oct 28, 2017 | Washing Machines
Whats a really good smelling perfume for teenage girls to buy?
Victoria's Secret PINK "fresh & clean"smells awesome and is cheap. They also make lotions and soaps in the scent.
Nov 23, 2010 | Dana Perfumes Loves Baby Soft by Dana Eau...
Foul Odor
Odor from the water softening system can be attributed to several causes.
The best way to see if it is coming from the softener is to by-pass the softener and run the COLD water only for several minutes and see if the smell continues. Now run the HOT water and see if smell is coming from the water heater.
Some causes may be:
1. Hydrogen sulfide in the water supply (the water chemistry can change)
2. Sulfate reducing bacteria. Almost all water supplies have sulfates and if bacteria gets introduced into the plumbing system it acts with the sulfates to create sulfate reducing bacteria. Which creates a rotten egg smell in the water.
3. Salt additives can have many different affects on water chemistry and organics in the water causing musty, fishy, swampy type smells.
4. If you have a system for Tannins using salts with additives will always cause foul smells as it harms the Tannin media.
5. The ANODE rod in the water heater degrades and gives off a sulfur type, rotten egg smell.
RJ
Jul 22, 2010 | Culligan Under Sink Water Filter
We purchased this product a month ago and it seems to be giving off a burning type of smell which we can smell both outside the vent and in the dryer itself. it seems to work fine
If it smells like an oily burn then it is just the oil burning off of the new parts in dryer, this is common. If it smells like electrical burning then call the manufacturer for repair. Could be a wire burning and if it is new it is covered under warranty.
Jun 14, 2010 | Whirlpool WED5800S Electric Dryer
We had a power outage - the computer was on a circuit breaker outlet. The other computer came back on, but the one with the siverstone power supply will not start up
Hmmm, First of all check the fuses if any that may have burned out due to the power outage. If this doesnt help. Open up the power supply and smell it for any burned out parts. If you can smell the scent of burned electrical parts then you should replace the power supply. It should solve your problem. Also check the motherboard for any anomalies.
May 19, 2010 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
Transmission maintenance schedule. How often does the Factory recommend to change the transmission fluid. V6 w/4wd average use.
Usually a transmission service interval is every 30k miles. I would have it checked, or check it yourself, at 15k miles to see if it looks or smells burned (dark red in color with a pungent scent) to determine if it needs to be serviced before 30k miles.
May 14, 2010 | 2008 Toyota RAV4
Kenmore Dryer 76812. The motor sounds like it wants to turn over but it smells like electrical burn and will not start. We cleaned all the lint from the back and around the motor. Any ideas on what we...
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...it will also get very hot and give you the burning electrical smell...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Apr 11, 2010 | Dryers
Dryer is heating but smells like something is burning. Clothes stink
HI,
i stronlgy suggest you that dont use it if you are smelling a un usual scent like burning wires.
to prevent any accidental that may occur.
bring your dryer or call a service technician to check parts by parts maybe some are only short circuited.
thanks,
May 28, 2009 | Dryers
GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Mar 07, 2009 | GE Dryers
Motor smells on model lde7314ace
If the motor smell burnt it is going to burn up soon. Unfortunatly it is time to replace the motor if it is worth it. You may consider a new one. Once the motor goes you can guarante that something else will follow.
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
LG 4.2 Cu. Ft. All-In-One Steam Washer and Dryer - White Logo
105 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
