Question about Dell Inspiron 2200 Notebook
Blue screen Fatal System Error. How do I get the laptop to work?
I was having trouble opening the internet so each time I powered up my INSPIRON 2200 I had to do a system restore. On this occasion however a blue screen poped up and will not go away; this is exactly what appears on the screen as below:
STOP: c000021a {FATAL SYSTEM ERROR}
The windows Logon Process system process terminated unexpectedly with a status of )xc0000135 (0x00000000 0x00000000).
The system has been shut down.
  • klawlor Apr 23, 2009
    How would I go about fixing this problem
    How would I go about fixing this problem?
    New Friend:
  • 79 Answers
Damaged OS windows or most commom hard drive failer..
Posted on Apr 23, 2009
  • matthew davies Apr 24, 2009
    it most prob just a OS window problem,, back up every thing you need.. on disks of exsternal memory etc ,, the use your recovery system or disk on pc.. this with completely wipe and reboot pc to when it was new please note this will wipe every thing you had on pc,, this should sort the problem,, if you still have problem with in the couple of weeks after with use ,  then you will need to replace hard drive
I have a Dell Inspiron 2200 and need to replace the motherboard....how do i disassemble the laptop to get to the system board?
if you are now a computer technician, it is advisable to take your laptop to one to avoid demage of some components. Anyway, carefully open the laptop disconnecting the screen, remove your key pad and unskoll the motherboard to be replace. replace and carefully transfer component ensuring none is demage
Sep 28, 2010 | Dell Inspiron 2200 Notebook
Hi, My laptop doesn't boot up. I got a blue screen with the following error message- STOP: c000021a {Fatal System Error} The initial session process or system process terminated unexpectedly with a status...
Thats known as a blue screen of death. you simply have to put in an operating system CD which is bootable (the one which you are currently using win xp vista or whatever) just boot through the cd ignore the first repair option and hit enter when the option for repairs appears for the second time just hit R and follow the options. you won't loose any data.
Aug 20, 2010 | Dell Inspiron 1525 Notebook
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
Stop: c000021a {fatal system error}
start in safe mode with command propmpt and type chkdsk /r/f and let the system get scan.
Jan 20, 2010 | Dell Inspiron Notebook
STOP: c000021a {Fatal System Error} .. 0xc0000005
The first thing you should do is back up the HDD, Remove the HDD from your Laptop, you find the lid that opens the HDD access slot under the laptop or ask someone who knows how. if available there are aftermarket 2.5 HD enclosures that lets you install the 2.5 in.hdd of your laptop via a usb. you can plug the usb to a desktop PC and backup your files. then reformat your hdd. reinstall the hdd to your laptop. replace your memory ram which causes the blue screen with a new ram, reinstall the OS.
Jul 07, 2009 | Dell Vostro 1510 Laptop Computer PC...
I have 2 laptops. One my my laptops (Inspiron 2200 Dell running on Windows XP home edition ) was working well until suddenly it would not connect to wireless internet. I am currently on my second laptop...
on your inspiron 2200...
1) click "start", "run", and type "services.msc"
2) select "wireless zero" at the bottom and check if it set to "automatic"
3) make sure that "wireless zero" is set to "start"
4) turn on inspiron 2200 wireless switch
5) right click wireless icon near to your computer's system time
6) click "view available wireless networks"
7) check if your wireless name is visible
Dec 05, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Dell inspiron 2200 is not powering up after being switched on, its on black screen! help
The most probable cause of failure is the memory sticks on the computer. Follow the troubleshooting steps given below and you would be able to get the system up
http://tinyurl.com/5gmvww
Thanks
Proton
Donot forget to rate the solution if it was helpful or resolve your issue
Jul 26, 2008 | Dell Inspiron 2200 Notebook
Blue screen error
first chk ur HDD on some other system. if the result is same then the only option is installing new OS.
Jun 25, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 2200 laptop Display Problem
just open your laptop battry and give its power by addepture and on it.if the problem is not solved check the addepture,after that change your laptop motherboard.layes69@yahoo.com
Apr 22, 2008 | Dell Inspiron 2200 PC Notebook
Dell Inspiron 2200 Notebook Logo
779 people viewed this question
Alun Cox
