Question about Qca Spas Majestic Series Aruba Xl Hot Tub
My tub has been off for about a year. now when i turn it on everything turns on about a every minute and runs for about a minute. it was on for about 2 hours and it did it the whole time.by everything i mean heater,blower,jets,circ pump. any ideas
  • 93 Answers
If you have a dial to set time check to see if it has its tabs pulled out push them in
Posted on Oct 16, 2013
2 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: Qca Spa pumps and blower will not come on, water down to 35º f
Ken,
You need to contact a hot tub technician/engineer as you clearly have issues.
'ICE' means that the water temperature is too low and therefore the pumps will be turned on to prevent freezing within the plumbing. Depending upon the spec and settings, the heater maybe disabled during 'ICE' condition.
'ECON' is Economy Mode. If you have a mode button, keep pressing it until you see 'Stan' on the display. This will put the system back into the standard mode.
'FLO' means that there's insufficient flow of water through the heater, or non at all. 1) Check the water level - top up if low. 2) Ensure that all jets are open and flow water - if they don't you may have a pump issue. 3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
'COOL' is displaying because the set temperature is much higher than the current water temperature.
As I mentioned at the start, you really should get someone to take a look at your hot tub. You may have a few issues that need resolving.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 17, 2010
HotSprings hot tub trips circuit breaker
Could be a wrong breaker for that circuit or a problem with the tub.
• first see if there are other lines on that circuit- should be only the tub.
• Check the specs for the tub that the circuit is the correct amperage.
• if clear on those items, there is a problem with the unit and that's another question.
Aug 16, 2014 | Electrical Supplies
What causes bubbler to turn off after 3 minutes of use in my kohler k1257-g tub
If your air blower does not run for more than about 3 minutes then you may have a bad motor.
Once it shuts down it should come back on in about 10 minutes after it cools down.
Every motor has a thermal protection built into it to prevent the motor from burning up.
If this is the situation then you will need a new motor.
Rod
US Parts Center
Mar 13, 2014 | Kohler K1257G47 Mariposa 6 Bubble Massage...
Lasco bubbler massage tub
Sounds like you may have a circuit that is bad in the control box under the tub.
Very unusual for that type of issue unless there is a problem on the circuitry.
Call a technician to have them trouble shoot it for you. It may need to be replaced. Those are not usually an item that is fixed.
Rod
US Parts Center
Feb 02, 2014 | Jacuzzi Nova Whirlpool Tub H532
Hot tub pump running unexpectedly
check the heater setting.. it may be the heater demanding cooler water to go through..it will cycle as needed by the heater..
Dec 27, 2013 | Pool & Spa
Maax tub
Some air jet bubbler blowers are designed to run for 5 to 10 minutes after you drain the tub to push all of the water out of the air channels. It should shut off on its own once it senses all of the water has been blown out. If it continues to run much longer than that, then contact the mfg for a service call. You have a warranty if it is a recent purchase that should cover it. Hope this helps!
Sep 10, 2017 | Home
How do you clean the jets in a whirlpool tub? Is there any product to put in water and run jets to clean them?
Put white vinegar in the water and run it through your tub. Fill the tub to it's maximum running capacity, which is normally just above the jets, and pour a gallon of vinegar in the water with it. Let it run with the vinegar for about 20 minutes, then turn it off and let the vinegar sit in the jets for about 30 minutes. Then start up the jets again for about another 10 minutes and drain. Then run plan water through the jets for about 15 minutes, drain and that should do it. I would recommend doing this at least once every 2 months depending on your water type and how often you use the tub.
Feb 13, 2013 | Home
Spinner on twin tub washing machine not spinning
I have had a manatee twin tub washing machine with spinner for two years. When I went to spin dry the first load this evening, it would turn on, but not spin. I read the above entry about another twin tub. I did the following... I unplugged the machine for 1 minute. Plugged it back in, then slowly and carefully turned the spin tub clockwise for 1/4 turn, then counter-clockwise for 1/4 turn. I cannot explain why it worked, but it did. So, try this trick before taking it apart. Good luck!
Jan 15, 2012 | Washing Machines
My washer, A612S, does everything correctly but SPIN in the spin cycles. Both belts underneath are fine. The motor pulley spin fine when in the spin cycle, but the belt doesn't. When I turn it off...
the brake it the drum directly above the transmission pulley it is not intergrated into the trans.
in my almost 30 years of repairs in that old and very reliable machine i would find where a article of clothing and floated over the inner tub and has wedged itsefl between the inner and outer tub, their is enough clerance between the tub and tub cover where you could get finger into it and run it around the tub and feel if a piece of clothing is caught. if that isnt the problem then the tub bearing is ceased up and would require repalcing it and the tub seal
Jul 18, 2011 | Maytag Washing Machines
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Jets shut off...
Most jetted tubs turn off after 20 to 30 minutes. It is a safety feature as well as a thermal protection feature for the motor. I doubt if there is anything wrong with your tub. If you contact the manufacture of the tub, they will most likey confirm what I have said to be what is going on. If it was a hot tub, like the ones used outdoors, this would signify a problem.
Sep 11, 2009 | Home
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
50 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
