Question about Swatch Watch, Unisex Swiss Digital Touch Screen Black Silicone Strap 3
Touch screen is not working - Swatch Watch, Unisex Swiss Digital Touch Screen Black Silicone Strap 3
  • Swatch Master
  • 18,424 Answers
Replace battery
Posted on Oct 11, 2013
Can't unlock the touch screen to set KC1850
I'm having the same problem. Has anyone figured it out - how to unlock the screen.
N.B. It worked previously, then stopped.
Dec 25, 2013 | Kenneth Cole New York Mens KC1850 KC-Touch...
My Tissot T-Touch Altimeter does not function.
Mine did the same thing; I read in other blogs that this could happen due to humidity. I heat up my watch with my wife's blower for about 5 minutes on high. After 5 min I couldn't even touch it! The screen went blank. After a few minutes when it cooled down the screen came back up and to my amazement all the function came back. it is risky but So far... it works well.
Sep 26, 2012 | Tissot T-Touch T33759851
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
Setting the time on the PU910222003 Puma ladies watch.
The process may be less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
Hi, My Tissot touch watch quit, it was just over 2 yrs old, and I took it to the local Jewelry Store that sold them. They sent it off to their Jeweler and he replaced the battery. Now the watch keeps...
If the Jewellery Store was not an Authorised Tissot Repair Centre then it is likely that they have made a mistake - the T-Touch is the only watch in the world that has a touch screen - so they may not be very familiar with it.
It may be going into setup mode because there has been a new battery just installed - go through the procedure and see if it works. - Pretend it is like brand new and you have to set it up for the first time.
Dec 14, 2010 | Tissot T-Touch T33159851 Wrist Watch
Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
Sep 22, 2009 | Tissot T-Touch T33159851 Wrist Watch
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Did you notice that this is TOUCH SCREEN? This is why you have just one resetting button. All the settings must be done using TOUCH SCREEN. So, Tap on appropriate icons on the screen and play with them till you find the right settings.
Unfortunately there is no instruction downloads available on the net, so, you have to find the way around yourself.
Rate me, please.
Mar 21, 2009 | Watches
Screen not working T Touch Titanium (Totally Useless)
I suggest you have to find the decent watchmaker and do not use dealers services anymore.In my opinion you have been overcharged in both cases.
Consider replacing touch screen if it is damaged and then sell it on ebay (anyway you do not like it). For watch in working order you have to get quite a decent money. If you gonna sell it as it is, you will get pennies only.
Later just buy another make and forget about this unlucky example. :))
Dec 07, 2008 | Tissot T-Touch T33159851 Wrist Watch
The touch screen dont work
hold the button until you hear a beep. then press on the glass. if not, return it.
Mar 18, 2008 | Tissot T-Touch T33759851
Swatch Watch, Unisex Swiss Digital Touch Screen Black Silicone Strap 3 Logo
134 people viewed this question
Top Swatch Watches Experts
Ansel Alberto
Ansel Alberto
Ian Browning
Ian Browning
Level 1 Expert
Are you a Swatch Watch Expert? Answer questions, earn points and help others
