Question about Microwave Ovens
I have an Emerson microwave model mw8999sb. If I press any button except "Start" the display shows "Def 1" and wont do anything. I can't set a particular time or choose any preset times on the display. What could be causing this and what is my fix? Thanks.
SOURCE: Neff 5474.0/gb. When microwave time
After a bit of digging, it appears to be an issue with the door not being closed correctly (or at least the it thinks is isn't.
Ref:http://www.sampfordixl.com.au/gaggenau/upload/BM221130_instr.pdf
I know its a different model but the functionality is identical...
Posted on Jun 12, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave R-320FQ Serial # 26805 Mfg. Dec. 2002
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
It may have an intermittently shorting keypad or another problem on the control panel, which we repair for customers nationwide with our guaranteed $39.95 service.
Posted on Aug 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Hi. I pressed the 'quickstart'
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Posted on Sep 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung MW1080STA Microwave Oven
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You can order Samsung parts here.
You can find your nearest Samsung-authorized service center here.
To find out if yours was recalled, please call Samsung's Service Division at 800-932-3837.
Posted on Nov 21, 2008
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
Model MW8999SB is not heating anything?
If the microwave powers up and everything appears to work then the problem is the magnetron, "heats food and is the heart of the unit" it is cheaper to replace the whole oven rather having it repaired.
Mar 03, 2012 | Emerson Microwave Ovens
Emerson MW8999SB 900-Watt Microwave replacement plate
From what I could find, it should be 10 1/2 inches in overall diameter.
meowpfttpftt
Mar 31, 2010 | Microwave Ovens
I have an emerson 900w microwave mw8999sb sn908003050mm. I have tried cooking in it and setting the timer at the same time to time something else that I am cooking. Can it be done with this type of...
The owner's manual is here, and it does not mention that as a feature.
One way to prove that is to press the "Kitchen Timer" pad while the oven is cooking and see if anything happens.
No modern microwave that we know of has this dual function, but it sounds interesting.
Nov 28, 2009 | Emerson MW8168B Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
54 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
