Question about Whirlpool AWM6100 Front Load Washer
I have a whirlpool duet washer and the clear plexiglass door cover is broken. I have a new one, what is the trick to installing the new one? im thinking i should warm it up a little so it expands and snap it on the mating part.
    Sergeant:
    Champion:
  • 257 Answers
No, this is not a right way to replace it by pushing from outside. You need to unscrew all the screw which are around of the door to get the plastic cover off, then you can replace the plexiglass door. The better way is take it off from the hinge, lay the door on the floor which the screws face-up. It is not a hard job to replace it.
Posted on Oct 22, 2013
SOURCE: whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Posted on Oct 05, 2008
aborcass
  • 2651 Answers
SOURCE: Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response http://www.keshakeaway.com/servlet/StoreFront
Posted on Mar 13, 2008
  • 8 Answers
SOURCE: Whirlpool Duet GHW9100LW2 Washer
Please check out my post at:
http://www.fixya.com/support/t1254687-duet_washer_very_loud_when_spinning
and let me know if yours looked similar.
Thanks,
Bill
Posted on Nov 23, 2008
agitateme
  • 88 Answers
SOURCE: 2003 Whirlpool Duet Washer clear water pooling in drum after use.
When the machine is off, there are only two ways water could possibly enter. 1 Check the drain hose install, that it is not installed deep in the standpipe, if the hose is shoved too deep, it can sometimes siphon (rare with front loaders) water back into the machine.
2. Most likely cause, a slow leak from the water valve. Sometimes the water solenoid will not close completely, and you will get a very, very slow leak into the machine.
If not the drain hose, try shutting off the water supply valves when done using the machine, if that takes care of it, you may want to replace the machine's inlet valve.
Posted on Apr 19, 2009
SOURCE: Whirlpool Duet washer door will not open
try pressing start and then pause/cancel immediately after. I just had this issue with mine
Posted on May 22, 2009
Broken Glass Sound
OK, who washing the dishes in the CLOTHES Machine?! Broken glass sound? You are sure your neighbor isn\'t playing a trick on you! I am going to guess that you have either a BAD bearing, in which it is time to look at Other Machines as an option. I mean if the clothes are getting clean and it drains all the water? Just shut the door! No I can\'t say that...Can I? Whirlpools (in my opinion) are one of the Best. The problems we are having today are these Front Load Machines are a Piece of Crap! They do not use enough water. You have to use Hi Definition 3X\'s more expensive soap..that doesn\'t Clean the garments. This sounds BAD. I had the same problem and bought a USED Whirlpool Top machine for $150 dollars from a guy who"Likes" to tinker/work on them and three years later...Going Strong! Sorry I could not help you
Jan 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer f3 e2 code
your main control board is having a problem need to have service rereplace it free of charge and the board has been upgraded
Sep 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Door lock wont engage error FDL
Door switch is broken, if still under warranty get them to fix it. If not call your local appliance man and get him to come out and install a new one. You can even get them to order the new switch and you can install. Not hard to do at all.
Oct 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have a whirlpool duet front loading washer. Recently bought a new house, only way to access basement is up 5 steps on side of house to landing with railing.cannot turn machine on landing so door is facing...
This may or may not be helpful but please see the following Whirlpool installation and service manual for the Duet Sport washer.
It has a number of sections on accessing components and you may be able to determine how to take the front off.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Following is the Whirlpool service manual for two other models of the Duet washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Oct 20, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
Can you adjust the door on the duet washer. I
You need to replace the hinge, sounds like it has worn out bushings.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need clear plastic cover for front of door
I have one. My new Bosch washer came 2 months ago and I removed it immediately.
The problem is that it arrived scratched up somewhat, which is another reason I removed it as this will only get worse with a plastic cover.
The cover also makes it harder to see into the machine while it's in operation.
To be honest, I'm not sure why you would want it on there, but if you really need one then mine is available.
May 25, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
F32 comes up when we just installed our new Whirlpool Duet Washer WFW9200SQ.
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool AWM6100 Front Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De
