Question about KitchenAid Kitchen Ranges
Replace light bulb - KitchenAid Kitchen Ranges
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
Tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
on Dec 18, 2009 | Honda Civic Cars & Trucks
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
I have a 2005 chev impala can i replace my high beams headlights with just low beam lights
NO YOU HAVE TO REPLACE HIGH BEAM LIGHT BULBS WITH HIGH BEAM LIGHT BULBS BECAUSE HIGH BEAM LIGHT BULBS AND LOW BEAM LIGHT BULBS TWO DIFFERENT TYPES OF BULBS.WEAR CLEAN LATEX GLOVES HANDLING THE HEADLIGHT BULBS WHICH IS HALOGEN LIGHT BULBS, OIL FROM FINGERS OR HAND WILL CAUSE HALOGEN BULBS TO OVER HEAT BLOW OUT.
Jul 05, 2011 | 2005 Chevrolet Impala
How to replace bulb in front bumper turn signal housing 1995 jag xj6
hello,
  • Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
  • Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
  • Remove the front turn signal light unit in the bumper to change the turn signal bulb. Push gently on the inside edge and insert a blade between the bumper and the lens at the outside edge. Compress the spring and remove the lens. Fit a new lamp by inserting it into the plug. The side marker light is changed using a similar process.
  • Open the trunk to replace the rear fog light, stop light, tail light, reversing light and turn signal light. Remove the rear light cover and turn the bulb holder fastener 90 degrees counter clockwise. Remove the expired bulb, fit a new one and replace the parts, turning the bulb holder clockwise.
  • Thanks..
    May 21, 2011 | 1995 Jaguar XJ6
    Change out a taillight
    You want to change the tail light bulb?
    The process for replacing tail light bulbs is the same in all models. If you have a burnt-out tail light bulb, you may need to replace the brake light, the reverse light or the turn signal. The procedure to replace each of the bulbs is the same.
      Instructions
      1. Open the Hummer's rear swing gate. This will expose the edge of the vehicle's tail light assembly. You'll see two small Phillips head screws that hold the tail light assembly in place. Put on your gloves.
      2. Remove the two screws from the tail light assembly. Pull the tail light out and inspect the back for two bulbs. The top bulb is the brake light and turn signal. The bottom bulb is the reverse bulb. Determine which bulb you need to replace.
      3Rotate the bulb's socket counterclockwise to disconnect it. Unplug the bulb from its socket.
      4Push the replacement bulb into its socket firmly. Insert the socket back into the tail light. Turn it clockwise to secure it in place.
      5Place the tail light into its cradle. Hold it with one hand and replace the Phillips head screws with the other.
    Dec 03, 2010 | 2008 Hummer H3
    How to change the light in the refrig. compartment?
    Some models are different...I hope this helps.
    Replacing Light Bulbs
    To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
    To avoid personal injury or property damage, observe the following:
    • Allow light bulb to cool.
    • Wear gloves when replacing light bulb.
    Fresh Food Section
    (style of light shield varies)
    1. Slide clear light shield toward back of compartment to release from light assembly.
    2. Remove light bulbs.
    3. Replace with appliance bulbs no greater than 40 watts.
    4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
    Freezer (style of light shield varies)
    1. Reach behind the light cover.
    2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
    3. Remove the cover.
    4. Remove light bulb
    5. Replace bulb with appliance bulb no greater than 40 watts.
    6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
    Ric
    Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
    1994 Acura vigor gear indicator light won't light D4. All other gear indicator lights work. Happened after replacing two dash lights
    WHILE REPLACEING OTHER DASH LIGHT BULBS THE JOSTLING JUST BURNT OUT THE ALREADY CLOSE TO FAILING D4 BULB.
    Jun 14, 2009 | 1992 Acura Vigor
    How to replace headlight on a 2003 Chevy Tracker
    There are two black plastic clips behind the the air filter, remove them and release the whole assembly to access the lights.
    If you still get in troubles, have it replaced at a petrol station, they will help you in fitting the bulb, and it won't be expensive.
    Here follows
    2003 Chevrolet Tracker Light Bulb Size Chart
    Low Beam Headlight Bulb Size: 9003/HB2
    High Beam Headlamp Light Bulb Size: 9003/HB2
    Parking Light Bulb Size: 1157A
    Front Turn Signal Light Bulb Size: 1157A
    Rear Turn Signal Light Bulb Size: 921
    Tail Light Bulb Size: 7443
    Stop Light Bulb Size: 7443
    High Mount Stop Light Bulb Size: 168 Or 921
    License Plate Light Bulb Size: 168
    Back Up Light Bulb Size: 921
    Front Sidemarker Light Bulb Size: 194
    Ash Tray Light Bulb Size: 74
    Step/Courtesy Light Bulb Size: 168
    Trunk/Cargo Area Light Bulb Size: 168
    Instrument-General Light Bulb Size: 158 or 74
    Check Engine Indicator Light Bulb Size: 74
    Hi-Beam Indicator Light Bulb Size: 74
    Seat Belt Indicator Light Bulb Size: 74
    Brake Warning Light Bulb Size: 74
    Automatic Transmission Indicator Light Bulb Size: 74
    Directional Signal Indicator Light Bulb Size: 74
    Oct 02, 2008 | 2003 Chevrolet Tracker
    Open Questions:
    Kitchen Ranges Logo
    Top KitchenAid Kitchen Ranges Experts
    Colin Stickland
    Colin Stickland
    Dan Webster
    Dan Webster
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
