Question about HP Pavilion dv6000z Notebook
Compaq 236875 004
Can I put in the first slot 2 G RAM, and 1 G RAM in the second slot?Thank You
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Yes as long as it is the correct ram: pc2, pc3 etc.. Check you specs online.
Posted on May 01, 2014
2 Suggested Answers
anand_manj20
  • 32 Answers
SOURCE: specification of ram, in the one slot i have 256 ram can i put 1 gb ram in second slot? can i put 1 gb ram in both slot ie 2 gb ram?
Hi
Yes you can use upto 2gb of ram max.
you can use the 1gb ram in single slot.
With Regards
Posted on Apr 19, 2009
Need a manual for an HP Compaq dc5100 pc
Really? It should be in Slot 1. (DIMM 1)
A Processor reads Slot 1 first.
http://h18000.www1.hp.com/products/quickspecs/12145_na/12145_na.HTML
http://images.search.yahoo.com/images/view?back=http%3A%2F%2Fsearch.yahoo.com%2Fsearch%3Fei%3DUTF-8%26p%3DHP%2BCompaq%2Bdc5100&w=160&h=120&imgurl=www.bing.com%2Fimages%2Fsearch%3Fq%3DHP%2BCompaq%2Bdc5100%26id%3D31AB48C49864E0586ACBE43C91C8A90B5517029C%23focal%3D0e9e115518bbca8a6cb3876be5fca118%26amp%3Bfurl%3Dhttp%253a%252f%252ffarm3.staticflickr.com%252f2223%252f2386577295_768b047fea_z.jpg&size=&name=search&rcurl=http%3A%2F%2Fwww.bing.com%2Fimages%2Fsearch%3Fq%3DHP%2BCompaq%2Bdc5100%26id%3D31AB48C49864E0586ACBE43C91C8A90B5517029C%23focal%3D0e9e115518bbca8a6cb3876be5fca118%26amp%3Bfurl%3Dhttp%253a%252f%252ffarm3.staticflickr.com%252f2223%252f2386577295_768b047fea_z.jpg&rurl=http%3A%2F%2Fwww.bing.com%2Fimages%2Fsearch%3Fq%3DHP%2BCompaq%2Bdc5100%26id%3D31AB48C49864E0586ACBE43C91C8A90B5517029C%23focal%3D0e9e115518bbca8a6cb3876be5fca118%26amp%3Bfurl%3Dhttp%253a%252f%252ffarm3.staticflickr.com%252f2223%252f2386577295_768b047fea_z.jpg&p=HP+Compaq+dc5100&type=&no=2&tt=115&oid=http%3A%2F%2Fts3.mm.bing.net%2Fimages%2Fthumbnail.aspx%3Fq%3D4788283556430266%26id%3Dcdd071ddf643fd3563a54323e0328aeb&***=HP+Compaq+dc5100+20080404081+%7C+Flickr+-+Photo+Sharing%21&sigr=16pkmjpub&sigi=16irimlt9&sigb=11q4rp0eh&fr=moz35
http://www.ebay.com/itm/HP-COMPAQ-DC5100-SOCKET-775-MOTHERBOARD-376570-001WITH-PENTIUM-4-2-8-GHZ-CPU-/320920013390?pt=Motherboards&hash=item4ab852ca4e
Scroll down to the larger photos of the motherboard.
Notice how the one Black ram memory slot is closer to the Processor?
That is Slot 1.
Keep the ram memory in the same color of ram memory slots.
Note*
IF you have the SAME ram memory modules ('Stick') in the Black slots, you will be running the ram memory in a dual channel configuration.
Same thing for the white ram memory slots.
Most generally the ram memory 'sticks' are bought from the same manufacturer, so as to guarantee they are indeed the same.
Same 'speed' (Frequency rate, actually)
Same voltage used
Same ram timings
Same chip configuration
Having the two LIKE ram memory modules installed in a dual channel configuration, allows them to team up on the task at hand.
Purported to speed up the ram memory functions greatly.
Up to 30 percent.
This has found out to be bullsticks.
The actual increase is more like 1 to 2 percent.
Nothing to write home to Mom about.
(Tom's Hardware used MANY different motherboards, ram memory, processors, and associated hardware, and tested different ram memory.
All came to the same conclusion. 1 to 2 percent increase.
Why do gamers use dual channel configuration?
1 to 2 percent increase. EVERY little bit helps)
I using a dual channel configuration for your motherboard, two LIKE ram memory modules are installed in Slots 1 and 3, (Black)
Have four LIKE ram memory modules? They go in Slots 2 and 4.
(White)
Regards,
joecoolvette
Jul 01, 2012 | HP Compaq dc5100 Small Form Factor PC...
Hello i would like to upgrade my ram (put in 2x 1 gb) in my hp compaq nx6310 but I can't find both slots, could you pls help me out?
The bottom has two user removeable covers. The first covers the hard drive and the second has the CPU, both RAM slots, and the Broadcom wireless card. pierreleg.jpg
Jul 21, 2011 | HP Compaq nx6310 Notebook
The board for this appears to have a dead ram slot.If putting ram into second slot the monitor just goes black with line distortions.Remove the Ram and install to first slot everything works ok add a 2nd...
Inspect the memory slot carefully. If there are are bent pins in the slot , you can probably align them with a pointed tip. Otherwise the best option would to replace the motherboard. Because after the process RAM is the fastest component in the computer. Out of experience in repairing the motherboards ,i recommend to replace the motherboard.
Thanks Fixya
Proton
Jun 17, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
New memory not recognized by Compaq Pavilion a1200y
most probably the problem that you have is not on the RAM stick itself but on the memory slot. Both memories can be detected by slot 1 indicates that both are working.. both working memories cant be detected in slot 2 which indicates a bad memory slot
Mar 16, 2010 | Computers & Internet
Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Nov 19, 2009 | Compaq Evo D510 PC Desktop
Can not find second ram chip
Remove both pieces of ram (mark them with a felt tip marker so you know which one is which), and clean the contacts on the ram and the slots with a pink pencil eraser. Be gentle though, you don't want to remove the gold on the contacts, just remove the oxidation and make 'em bright again. You can shape the eraser to fit the slot with a sharp knife - and be sure to remove the eraser debris from the slots with a soft brush (dry toothbrush is good) . If still no good try this:
  1. Remove both pieces of ram.
  2. insert the second piece of ram in the first slot (leave the other slot empty) If the second piece of ram is detected, then the ram is good, and the second slot is likely the problem. If the ram is not detected, then the second stick of ram is the problem. Confirm this by putting ram stick 1 into slot 2. If the known good stick of ram (1) doesn't work in slot 2, then the slot is dead. If this is the case, get a larger stick of ram for slot 1. Let me know if this helps or not.
Aug 08, 2009 | Computers & Internet
Adding an additional memory module to laptop...wont start!!!
The problem is that your laptop only supports 2 GB of RAM. If there is not a newer bios allowing more then 2 GB is the max you can go. Since you put the 2 GB in one slot then the other slot will be useless. It wouldn't matter how much you put in the 2nd slot because the bios already says you have 2 GB on board and will not accept anymore. Sorry.
Apr 08, 2009 | HP Compaq Presario C500t Notebook
Upgrade ram
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot. 2 slots=1 gig or 1024MB ram.
May 22, 2008 | Compaq Presario M2000 Notebook
Compaq M700 Ram Upgrade the second
i can find no spec on this but,if your notebook can take upt 576MB of memory, i would expect 2 x 256MB to be the max, as installing 1 x 512MB would be doubling the capacity allowed by one module slot.
Oct 01, 2007 | Compaq Armada M700 Notebook
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
