Question about Casio FX991MS Scientific Calculator
Date on Canon MP11DX calculator keeps randomly changing overnight. I've reset it to the correct date four times in the last two weeks, but every morning I come back to work and the date has changed to a completely different month and date.
  • Casio Master
  • 7,993 Answers
If the Canon MP11DX has a backup battery, it may be spent, and it should be replaced with a fresh one.
Posted on Oct 11, 2013
  • k24674 Oct 11, 2013
    I checked and it uses AC power. Then maybe during the night, you have some disturbabces in the power line and the power may have gone out and the system date gets reset.
4 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: old Casio CP-10 printing calculator w/calendar
have you try to press the SET button after you enter the date, and before you make entry on the time
Posted on Jun 25, 2008
SOURCE: CASIO DR250TM CALCULATOR
In case you haven't found the solution yet. This is it.
Move buttons to "Print" and "F"
Press CA key
Press % (set Key)
Press "time"
Press and hold down the % (set key) until the numbers come back and start flashing.
Put in the correct numbers.
Press % (set key) again and your done.
Hope this helps.
Linda
Posted on Feb 11, 2009
  • 12 Answers
SOURCE: how do i change the time and date
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Posted on Jan 29, 2010
How do I set the date for this Canon MP11dx? I
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
Enjoy!
Apr 09, 2010 | Canon MP-11DX Calculator
How to reset the clock?
Push the button with the clock and calendar, this is directly over the 'cost' button, to display the date or time. Then use the 'Time set' button (this is the one for Memory - Plus - Equal). Hold the 'Time set' button down until the first figure blinks then release it. Use the number buttons to change the setting. When you have gotten the correct date or time entered oress the 'Time Set' button again.
Although it is only printed with 'Time Set' the button works for the date just as well.
Mar 30, 2010 | Canon P23-DH Calculator
How do I change the date on the Canon MP11DX calculator?
Check the user manual here
I searched this for you, pls leave a good rating
Oct 21, 2009 | Canon Office Equipment & Supplies
Date/time stamper will not print correctly
mine is doing the same thing. I read that the 3V battery may need to be changed.... so I changed the 3V and all four AA batteries and hit reset and am still experiencing the same as you. Random **** printing when display seems okay. Never same stuff twice. Very frustrating.
Jun 18, 2009 | Dymo DateMark Date/Time Stamper
MP11DX time and date will not set
I just did it over and over again, I think I may have even hit the = afterl. To change the AM hold down the calendar key, then the div
Jun 17, 2009 | Canon MP-11DX Calculator
I have the same problem I can not change date and time
Setting the date:
Setting the time:
displayed.
NOTE: If unsuccessful attempts to set the date and time have been made,
please first confirm that the piece of paper/plastic in the battery
compartment on the bottom of the unit has been removed. Then reset the
unit by inserting the tip of a ball point pen into the "RESET" hole on
the bottom of the calculator. The calculator should be on and in the
"Print" mode so that you can hear the calculator reset.
Aug 09, 2008 | Canon MP-25DV Calculator
Canon MP11DX
press the date/time button
press and hold the = button
once blinking set the date
press the = button again
once blinking set the time
the "x" button changes A / P
press the + button again
Feb 29, 2008 | Canon LS-100TS Calculator
Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Nov 30, 2007 | Canon P23-DH Calculator
Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
Jan 28, 2007 | Canon P170-DH Calculator
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
Casio FX991MS Scientific Calculator Logo
301 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
