Question about Husqvarna Garden
Adjust idle - Husqvarna Garden
  • Husqvarna Master
  • 7,482 Answers
Hi Sean
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Bud
Posted on Oct 11, 2013
Idle adjustment at carburator end
most older cars had 2 adjustments , a air screw for enrichment and throttle screw for engine idle speed, later models did away with the enrichment screw, to adjust set idle screw to 600 rpm, adjust air mixture screw to fastest rpm , reset idle screw to preferred idle speed.
Oct 03, 2016 | Cars & Trucks
Set idling via screws
Most older cars had 2 adjustments , a air screw for enrichment and throttle screw for engine idle speed, later models did away with the enrichment screw, to adjust set idle screw to 600 rpm, adjust air mixture screw to fastest rpm , reset idle screw to preferred idle speed.
How do I adjust idle speed?
You can't adjust the idle , There is a minimum idle adjustment set at the factory , you don't want to mess with that . The PCM / ECM ,engine computer controls the idle speed by the idle air control valve (motor) . You may have a dirty throttle plate mess with the base idle .Check out this video on ford base idle adjustment . Some one who didn't know cranked up the base idle causing problems Ford IAC valve test how to adjust minimum idle speed
Dec 19, 2015 | 1996 Ford Contour
It idles fast if I turn the idle down it stalls running rich on top end at fast idle sometimes it will drop to a very low idle and shut off
adjust the idle mixture screws first and then adjust the idle speed screw to compensate
adjusting the idle mixture screws will alter the idle speed but when properly adjusted then adjust the idle speed screw,
Aug 24, 2015 | Motorcycles
How do I adjust the idle speed on a Toyota Corolla Verso
you can adjust the idle air right at the air intake
Feb 25, 2015 | Toyota Corolla Cars & Trucks
Adjust idle up on poulan pro 42 cc chain saw
Adjust the low side out another quarter turn first before messing with the idle screw.
Sep 15, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the problem if carburetor idles high even when valves (mixture, idle) are at low adjustment?
are you allowing the car to warm up first before checking your adjustment screws? have you also checked the timing of your vehicle?
Jul 28, 2014 | 1990 Toyota Corolla
Idle adjust
It should have a base idle adjustment and could also have an idle speed control motor.
The base idle screw should be on the driver's side of the carb. You would also have a fast idle screw on the choke.
Aug 23, 2012 | Cars & Trucks
Member Discussion on Husqvarna 240e Chainsaw Idle Adjustment I have a new 240e and cannot keep it running. It will start, after many pulls, and one of two things happens. After running for 30...
Its not an idle screw adjustment issue, it is a mixture screw adjustment issue, unfortunatly there is a special tool to adjust the mixture screws, pt no. 530035560 ( available from Hysqvarna dealers ) once you have this tool you can make an adjustment to the L screw on the carb, undo ( anti clock wise ) this screw ten minutes on a clock face ,this will richen the muxture, and should make it more stable on idle.
Oct 07, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
How do you adjust the idle for a 2002 gmc safari
the idle isn't adjustable. you might want to have the idle air control motor checked out. they are prone to sticking in the open position allowing more air into the intake
Jun 04, 2009 | 2002 GMC Safari
Garden Logo
172 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
