Question about Lexmark Wheelwriter 1000 Typewriter
It is stuck in the left margin and is making a noise when I turn on the typewriter because it keeps pushing to the left.
  • 3594 Answers
SOURCE: selectric II typewriter
If you know how to remove the cabinet and dust covers spray every moving part with WD40 especially the cams and parts under the R. dust cover.
DickyO
Posted on Aug 11, 2008
  • 3594 Answers
SOURCE: IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
DickyO
Posted on May 28, 2009
  • 14 Answers
SOURCE: My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Posted on Oct 14, 2009
  • 3594 Answers
SOURCE: The left margin is stuck
Put a shot of WD40 on both sides of the silver shaft that the carroer slides on. If that doesn't do it put some on the carier motor bearings. The front one can be reached from inside of the T/W the rear one yuo will have to remove the case of fish the straw thru it. The motor is located on the R. rear corner.
DickyO
Posted on Apr 05, 2011
  • 3594 Answers
SOURCE: Lexmark/IBM Wheelwriter 1000 Typewriter has
First try a little shot of WD40 on both sides of the silver shaft that the carrier slides on. If that doesn't do it you will have to get some on the carrier motor bearings located in the R. rear corner under the case.
DickyO
Posted on Apr 21, 2011
Testimonial: "This worked! No issues any more! Thanks :0)"
How to reset margins on Nakajima typewriter AE-830?
To set the left margin, space or backspace to the margin you want, then push the left margin button, do the same for the right margin.
Aug 19, 2014 | Nakajima Office Equipment & Supplies
Left margin stuck at center of page What to do besides reset margins? Can't back up to reset the left margin
You have to push the Mar Rel key then backspace to the new margin and press the Left Mar key
Jun 05, 2014 | IBM Wheelwriter 6 Typewriter
Left margin
.While gently pushing the carrier to the left pivot the tab set/clear button. The carrier may be stuck on a tab.
Nov 20, 2013 | Royal Scrittore Portable Manual Typewriter
My Nakajima AE-710 margin release does not work. How can I reset to factory settings?
When using the margin release DON'T HOLD IT DOWN just press and release. if this dosen/t work turn off the machine and see if the carrier will move both ways relatively freely if not look fot debris and spray a little WD40 on the silver shaft that it slides on.
DickyO
May 08, 2012 | Nakajima AE-710 Typewriter
The return is stuck on 80 on the guide. I cannot
Turn the T/W off and slide the carrier back and forth. If it goes to the left then you have the L. margin set at 80.
Return to the margin, press and release the margin release key, backspace to the desired location, press the L. margin key.
DickyO
Mar 18, 2010 | Nakajima AE-710 Typewriter
The left margin of my old IBM is stuck way off to
The margins are reset by pushing the silver knob to the back and sliding the margin set to the left or right. If it has been in the same place for a long time a little WD40 may be helpful.
DickyO
Nov 26, 2009 | IBM Office Equipment & Supplies
My typewriter is stuck at the left margin. I
My guess would be that the left and right margins are set at the same place. Try resetting the right margin and see if that's the problem. I used to experience this a lot with kids playing with the typewriter.
Oct 15, 2009 | Brother ML-300 Typewriter
DickyO
Mar 11, 2009 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 1000 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
