Question about Ranger Communications 1998 1999 2000 Ford Ranger Double Din Radio Install Kit
I got a 2000 ranger with 4.0 in it and my speed odometer not working and the ABS light on with door ajar and service engine and i put gem unit in it and it didnt fix the issue where do i go to now
    Top Expert:
  • Ranger Commu... Master
  • 10,875 Answers
Get a speed sensor,a door switch,and new brakes,i had the same truck with the same problems.the abs has to do with the front brakes,the abs unit is on the drivers side under the hood.
Posted on May 26, 2015
1999 Ford Explorer,Door ajar light & Chime goes on & off while driving,int lights & auto headlights won't shut off after car off & all doors closed.
Your best bet would be to find a Tech like this guy , with the right diagnostic equiment . Door Locks Go Crazy 1 Unless you know how to do automotive electrical testing . Your door ajar switch is a input to a body control module . or GEM as ford calls thiers .
Door Locks Go Crazy 2 Your auto lights are controlled pretty much the same .
Electric Testing Techniques You Need to Know
Do you know what DTC"S are ? diagnostic trouble codes ! You probably have a door ajar switch problem . You need a factory or professional type scan tool to check these codes
B1322 Door Ajar Driver Circuit Short to Ground GEM/CTM REFER to Section 417-02 . B1323 Door Ajar Lamp Circuit Failure GEM/CTM REFER to Section 413-01 . B1325 Door Ajar Lamp Circuit Short to Battery GEM/CTM REFER to Section 413-01 . B1330 Door Ajar RF Circuit Short to Ground GEM/CTM REFER to Section 417-02 . B1334 Decklid Ajar Rear Door Circuit Short to Ground GEM/CTM REFER to Section 417-02 . B1338 RR Door Ajar Circuit Short to Ground GEM/CTM REFER to Section 417-02 . B1340 Chime Input Request Circuit Short to Ground GEM/CTM GO to Pinpoint Test C .
  • The Autolamps Are On Continuously
  • Circuitry.
  • Headlamp relay.
  • Light sensor amplifier.
  • Go To Pinpoint Test H .
  • The Autolamp Time Delay Is Inoperative
  • Fuse(s).
  • Headlamp switch.
  • Circuitry.
  • VERIFY parking lamp operation. If OK, REPLACE the light sensor amplifier. If any parking lamp concerns exist, Parking, Rear and License Lamps REFER to Parking, Rear or License Lamps.
Do you see how complex these systems can be for someone that doesn't deal with these problems on a daily base's ! Check for codes an if there are any , doing the diagnostic's associated with it . Without doing the diagnostic's you could replace parts all day long an not fix the problem .
2002 2005 Ford Explorer Door Ajar Light Common Door Wiring Faults
Apr 23, 2017 | Ford Cars & Trucks
Where is the courtesy light switch in the drivers door on a 1998 Navigator
courtesy light switch , is door ajar switch an it's part of the door lock actuator . Light on coming on ? Not going off ? The ajar switch is a input to the GEM module , fords BCM - body control module . The GEM will energize a relay to turn on the lights .
The GEM will illuminate the interior lamps when any door is open or ajar. The interior lamps are; the dome lamp, the rear cargo lamp, the door courtesy lamp and the side rail lamps. The courtesy lamps will shut off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps will not be reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp switch is received.
The GEM controls the interior lamps illuminated entry function by activating the interior lamp relay.
Mite be a good idea to have it check for DTC'S - diagnostic trouble codes .
B1322 Driver Door Ajar Circuit Short to Ground GEM GO to Pinpoint Test B . B1323 Door Ajar Lamp Circuit Failure GEM REFER to Section 413-01 . B1325 Door Ajar Lamp Circuit Short to Battery GEM REFER to Section 413-01 . B1330 Passenger Door Ajar Circuit Short to Ground GEM REFER to Section 417-02 . B1334 Decklid Ajar Rear Door Circuit Short to Ground GEM GO to Pinpoint Test C . B1338 Door Ajar RR Circuit Short to Ground
Mar 26, 2017 | 1998 Lincoln Navigator
ABS and TC light on. Speedometer and odometer are not working
If the speedo and odometer are not working it could be the speed sensor in the transmission. And the speed sensor could also knock out the ABS and traction control systems.
Have you had the body computer scanned for trouble codes ?
Sep 03, 2012 | 2000 Cadillac Catera
FORD Ranger ABS/OD problem
This might help a ton and save you money! So easy to fix, this video sounds like the same problem described! ABS light on, o/d flashing, check engine light on, tranny seems to be having issues, speedometer stops working. All fixed as described by the first answer james_hust , not tying to take your mojo but the video shows you what you need to do.
Dec 02, 2009 | 2000 Ford Ranger SuperCab
Diagram of 1996 ford ranger fusebox which fuse is
RANGER FUSE PANEL Fuse Position Rating Circuit Protected 1 7.5 Amp Power Mirror 2 — Not Used 3 15 Amp Parking Lamps 4 10 Amp Left Headlamp 5 10 Amp On Board Diagnostic (OBD) II System 6 7.5 Amp Air Bag System/Blower Relay 7 7.5 Amp Illumination Switches 8 10 Amp Right Headlamp/Fog Lamp System 9 10 Amp ABS System 10 7.5 Amp Speed Control/GEM System/Brake Interlock 11 7.5 Amp Warning Lamps 12 10 Amp Front Washer System 13 15 Amp PCM System/Stoplamps/
4WD/ABS/Speed Control 14 10/20 Amp ABS System 15 7.5 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 15 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 7.5 Amp Radio/GEM System/Anti-Theft 21 15 Amp Hazard Lamps 22 10 Amp Turn Signals 23 — Not Used 24 10 Amp Starter Relay/Anti-Theft 25 7.5 Amp Speedometer/GEM System 26 10 Amp 4R44E/4R55E Trans./Backup Lamps/DRL System 27 10 Amp Underhood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/4x4 Sys. 28 7.5 Amp GEM System 29 10 Amp Audio System 30 — Not Used 31 — Not Used 32 — Not Used 33 15 Amp High Beam Lamps 34 — Not Used 6d47eae.gif
Nov 01, 2009 | 1996 Ford Ranger SuperCab
ELECTRICAL PROBLEM DASH INSTRUMENTS
Start buy spending $30 dollars on a speed sencor attached to the top of the differential that should remove the OD flashing light and the ABS Light also fix the speedo not sure about the service engine soon light that could be many other problems..Good Luck!
Jun 19, 2009 | 1999 Ford F250 Regular Cab
2000 ford ranger speedo quit working
speed sensor in trans faulty,connections at sensor,wiring broken
May 09, 2009 | 1993 Ford Ranger SuperCab
Brake light and ABS light is on and the speedometer, odometer and tripometer are inoperable
replace the left front wheel hub assy. with 4 wheel abs. The spedometer works off of the left front wheel sensor. It will fix the abs/brake light and the spedometer will start working
Jul 23, 2008 | 1999 Dodge Durango
Odometer stopped working and service engine light stays on. Is anyone familiar with this problem?
REPLACE THE SPEED SENSOR ON THE PUMPKIN LOCATED ABOVE THE DRIVE SHAFT. THEY ARE ABOUT 15 BUCKS.
Jul 06, 2008 | 2000 Ford Ranger SuperCab
Ranger Communications 1998 1999 2000 Ford Ranger Double Din Radio Install Kit Logo
141 people viewed this question
Top Ranger Communications Car Audio & Video Experts
xxxxxx xxx
Are you a Ranger Communications Car Audio and Video Expert? Answer questions, earn points and help others
