Question about Verbatim 53029 Store n Go 500GB USB 3.0 2.5 Inch External Hard Drive Black
I got this Vertatim model 53029 500GB. My problem is, that the USB-port on the extern hard disk went inside the hard disk, when I accidentally dropped it on the floor... Is there anyone who can help me??! or tell me what to do to fix it up (know I have to open it, but how??!)??! I got all my schoolwork, photos ect. on it...
    Sergeant:
  • 240 Answers
The only information that I could find is HERE.
A video illustrating how to disassemble that drive is HERE.
I ran across THIS VIDEO that shows an easier way, but it is a different brand. It's worth checking to see if your Verbatim is set up the same way, usually these manufacturers all build the same way.
The second video (link posted above) shows a guy using a credit card to remove the cover, so it's simple. Just remove the cover and you can better see the situation.
Evidently Verbatim uses retail hard drives in their own plastic case. These drives have a small USB converter circuit board that plugs into the rear of the SATA hard drive and that is what you attach the USB cable to. It may be that only the mounting studs popped out and shoved the USB connector back in to the housing and it will still work. Once you get it open, connect it to the cable and try to make it work and you can get your data off of it. Another option is that these universal connectors are available. Try Newegg.com, or definitely try Ebay, there are lots of suppliers for that kind of equipment, I use several suppliers on Ebay all the time for repairs.
Hopefully the read/write heads were not physically damaged when it fell, but you won't know that until you try to start it up. If you hear a rattling, clicking noise when it tries to boot, I am afraid there are no other options.
Posted on Oct 12, 2013
4 Suggested Answers
  • 11 Answers
SOURCE: usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
Posted on Jun 08, 2009
yammy_alf
  • 666 Answers
SOURCE: I have a 320 gig
try testing connection of port from usb and firewire port. it not working we need to check for possible board controller swapping if available.
Posted on May 13, 2010
citroenchris
  • 600 Answers
SOURCE: My usb powered, 750gb external
Have rou repaired permissions, there is a how to in the tips section.
Posted on Mar 02, 2011
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
My Beyond Macro External hard drive model no BMMDU2 has stopped working.. It shows up in list of "Safely remove Hardware" but windows XP professional SP3 is not assigning any letter to...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
The piece that allows a usb cord to connect to the actual external hard drive broke off and i no longer can plug it into my computer. how do i get the piece out or fix it?
* the USB cable
* the power-adapter
Or, buy an "empty" external disk-drive enclosure, for about $30, and "transplant" your disk-drive into this enclosure.
Nov 21, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
We understand that your problem is: hello i was using my buffalo ministation 320 gb external hard drive about a week ago, it was working fine but I left it on my bed when I was done. About 2 days later I...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 06, 2010 | Buffalo Technology 320GB Ministation...
My PC failed to detect the transcend external hard drive. My name is Edwin Kakulu
* USB cable
Nov 04, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I have a 250 gb simpletech external hard drive. no. 96200-41001-077. I have used it as the time machine backup on my MacBook. It stopped backing up time machine recently. I got the message. Backup failed...
> icon does not show up on the desktop or finder
A major "clue" that one component of the external storage device has failed, namely:
* USB cable (try a different one)
* optionally, the external power-supply that connects to the enclosure
Use a multi-meter to verify the voltage/amperage output of that power-supply.
(Not all external storage devices need such a power-supply.)
> can it be saved?
Partially. Disassemble the enclosure, and remove the disk-drive.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage-device. (Compare it to a heart-transplant -- same body, new heart.)
Nov 03, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
My hardrive "simpledrive" model 96300-41001-156
* USB cable
Nov 03, 2010 | SimpleTech SimpleDrive Portable USB 2.0...
1 tb external hard disk. Will not back up, won't get off cleaning up or indexing backup. No noise, but when I touch it, it fells like something is rubbing inside.
* USB cable
Nov 02, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Usb pulled out during use now not working
Sometimes when a flash memory stick or USB hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory or USB external hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 27, 2009 | Western Digital My Book (WDG1U2500)...
External USB Disk is installed but not visible under Mu Computer
Go to manage, refresh, and then asign a letter to it.
--- tuljo
Feb 23, 2009 | Western Digital External USB 2.0 80 GB...
Verbatim 53029 Store n Go 500GB USB 3.0 2.5 Inch External Hard Drive Black Logo
236 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
