Question about Insignia IS 20" TV040919 TV
I HAVE AN INSGNIA 24" (NOT SURE OF MODEL)
I WAS WATCHING THE SET WHEN ALL OF A SUDDEN THE SCREEN REDUCES TO ABOUT AN INCH TALL AND EXTENDS ACROSS THE WHOLE SET. THE AUDIO IS CLEAR, BUT I CANT SEE ANY ON SCREEN OPTIONS TO INCREASE THE VIEWING AREA. AM I HOPELESS WITHOUT A TECHNICIAN VISITING?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As it has developed watching tv so it is a part failure in vertical section. in vertical there is a feed back ckt.it is due to electrolytic capacitor (most probably)or any other component but in feed back ckt. it is a common failure it is not major problem.can be rectified at your place with in no time by a skilled tech.
Posted on Sep 25, 2007
SOURCE:
Watching tv and all of a sudden it starts flipping through the channels and won't stop
If you have _no antenna_, make sure the menu (for channels) is set to either ''cable'' or ''satellite''. The TV needs to _know_ there are no ''antenna'' channels to scan for.
If the above doesn't work, try unplugging for a _full_ 24 hours. Then plug in, turn it on, go directly into ''menu'' and do like I stated above.
Note: ''Capacitors'' can ''hold memory'' for a long time. That is why ''unplug for full 24 hrs.''
May 18, 2015 | Westinghouse 32 Flat Screen 720p Hd Led...
KD-34XBR970 CRT HDTV startup problem
This is a failure in the vertical amp section. One way to troubleshoot it is to get a can of freeze spray and use it on the suspect components. The other way is to inspect all the solder joints on the amp. Last would be to check voltages on the board. Since it does change with run time, it is being affected by heat.
Mar 12, 2017 | Televison & Video
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Dishwasher for 32 inch cabinets
Miele makes a G600 series that are 32 1/4 " tall - that would probably be your best bet.
Jan 05, 2009 | Dishwashers
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Insignia IS 20" TV040919 TV Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
