Question about Whirlpool AWZ410 Front Load Washer/Dryer
Door locked open harness - Whirlpool AWZ410 Front Load Washer/Dryer
Power went out door locked
Instructions
<:section abp="1260">
    • 1 Unplug your Whirlpool Duet washer from the wall receptacle.
    • 2 Remove the three screws along the bottom front of the washer. Pull the bottom panel from the washer, opening the front of the washer.
    • 3 Reach your arm up through the opening to locate the door latch assemble inside the body of the washer. Grasp the tear-shaped tab with your fingers. Gently pull down on the tab until you hear a click. Pull on the Duet door to open it.
    • 4 Look inside the latch opening in the body of the washer for foreign material. Remove it from the switch with tweezers or needle-nose pliers. Look for any pieces of broken plastic that could indicate the door lock mechanism is broken and needs replacing.
    • 5 Shut the door on the washer and plug it into the wall receptacle. Confirm that the door remains unlocked. Unplug the washer and release the lock on the washer door as before if it fails to remain unlocked.
    • 6 Unplug the Duet washer from the receptacle. Pull the washer from the wall so you can access the rear of the washer.
    • 7 Remove the three screws from the top back of the Duet washer. Lift the top off the washer. Find the central control unit, or CCU, at the back right of the washing machine.
    • 8 Check that all the wiring harnesses plug securely into the CCU. The wiring harness for the door-lock solenoids is the sixth harness from the left of the CCU. The wiring harness for the door-lock main switches is the only black harness connected to the CCU.
    • 9 Remove the round retainer holding the rubber boot gasket from the Duet washer door opening by inserting a flat-head screwdriver beneath the spring on the retainer. Pull forward on the retainer spring to release it from the boot gasket.
    • 10 Pull the rubber boot gasket away from the opening at the switch location to access the door switch assembly. Check the wiring harness on the switch assembly to make sure it is engaged. Snap the gasket back in place, and replace the retainer on the washer.
    • 11 Plug the Duet washer into the wall receptacle. Select a washing cycle and press start. Listen for the door lock to engage. Turn the washer off and listen for the door lock to disengage, or wait 30 seconds and try to open the washer door.
    • 12 Unplug the washer from the wall receptacle. Pull the wiring harness for the door-lock solenoids from the CCU. Number the sets of wires attached to the wiring harness as 3, 2 and 1, from left to right.
    • 13 Set an electrical multimeter to "Ohm X1K." Insert one probe from the multimeter into opening number 3, along with the wire. Insert the remaining probe into opening number 2, along with the wires. The multimeter should read 60 ohms. Leave the probe in opening number 3, and move the remaining probe to opening number 1. The multimeter should read 60 ohms in this position as well. Should you receive any other reading, replace the wiring harness.
    • 14 Reconnect the wiring harness for the door-lock solenoids into the CCU. Plug the Duet washing machine into the wall receptacle. Select a wash cycle on the duet, then press start. Listen for the door lock to engage and immediately unplug the washer from the wall.
    • 15 Leave the wiring harness for the door-lock main switches plugged into the CCU. Number the wires in the harness 5, 4, 2 and 1, from left to right. The middle opening on the wiring harness is empty, so there isn't a third wire.
    • 16 Set the dial on the electrical multimeter to "Ohms X1K." Insert one probe into the opening next to wire 5, and insert the remaining probe into the opening next to wire 4. The meter should read zero ohms.
    • 17 Insert one probe into the opening next to wire number 2, and insert the remaining probe into the opening next to wire 1. The meter should read zero ohms. Replace the wiring harness should you receive any other reading.
Found this on the web . Hope this helps
Mar 30, 2014 | Whirlpool Duet WFW9750WW White Front Load...
My Yukon denali passenger side door has no power mirror,lock andwindow
ok if the wire is not cut open the small triangle panel on side of dash accessible only with door open. there are you will see the harness plugs for the door. check if they are still locked in and or if they have power to them. (note the right door is controlled by the left door,,, check the harness on the driver side and the switch panel on driver side door for a loose or unplugged harness
Nov 02, 2013 | 2003 GMC Yukon XL
Reset computer
If you pushed the car by the door itself or swung the door open hard, you could ha e stretched the door harness and pulled wires apart. There is a little accordian styled boot that 'protects, the wire loom leading to the driver door electronics. I wonder if you have noticed your alarm horn doesnt beep when locking the doors from the remote. Or you can only lock and unlock the driver door only from the driver door. If thats the case there may be an open in the wires leading to the door lock actuator; which controls things like lock/unlock functions of all doors and windows, door warning lights, etc. Have the harness repaired
Oct 07, 2013 | 2001 Volkswagen Jetta TDI
2001 beetle passenger door wont lock
You may want to check your wiring harness to that door. The harness runs along the door frame, by door hinge area and it's inside a rubber boot. Most common problem is that a few wires break due to heat and age. If wiring is broken, repair wires if possible. If not possible to repair, recommend you replace the complete harness.
If you are mechanically inclined, you will need to remove the inner door panel to access the harness. Once you have the harness removed, there is a label that identifies the part number for this harness. Good luck and hope this resolves your problem.
Jun 24, 2017 | 2001 Volkswagen Beetle
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
My machine wach but do not spin a the end.
Note: This solution is intended only for asker qualityisc as per Live Chat session discussion. Error code reads E47 which means the Control board thinks the PTC circuit (wax motor) is open.
Unplug the machine then remove the spring-loaded wire loop that holds in place the front of the bellows over the lip of the door opening in the front panel.
Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows then pull the bellows off of the lip of the front panel.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine and disconnect the electrical connections.
Measure the resistance of the wax motor. The normal resistance is around 1500 ohms. Shorted or open circuit wax motor means the door lock and switch assembly needs to be replaced.
Simply
replace the door lock and switch assembly (part #131763202) if the wax motor reads shorted or open to address the issue. But if the wax motor resistance is normal, check the continuity of the door lock and switch assembly wire harness, particularly the wax motor wire harness. Start with the continuity of the red/black wire of the wax motor harness to each of the red/black wires of the door lock and switch assembly harness. They should all have continuity; otherwise, replace the harness.
Remove the top panel to access the control board if further continuity test is necessary or if the red/black wire of the wax motor harness has continuity with the all other red/black wires of the door lock and switch assembly harness.
Remove the screws attaching the top panel to the rear of the cabinet then lift the panel off. The console can be removed from the cabinet to completely access the control board connections, particularly the door lock and switch assembly harness connections. Check the continuity of the red/black wires at the door lock and switch assembly to the red/black wire of the harness connected to connector J2 on the control board.
The problem is in the control board if the wax motor is good and the door lock and switch assembly wire harness has all the necessary continuity. The only viable solution, should that be the case, is the replacement of the control board.
Oct 03, 2010 | Frigidaire GLTF2940ES Front Load Washer
My Whirlpool Duet washer will not start. I keep getting a "dl" and an "f" signal. I assume it means door lock failure. I've tried unplugging and opening and shutting the door before restarting but it won't...
It is indeed a door lock failure. Replace the door lock/latch assembly (part number 8181700) to solve the problem.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Mar 01, 2010 | Washing Machines
Door locks open by themselves randomly
some possibilities
The power door locks may self-activate or cycle on some vehicles. This may be caused by a misadjusted front door lock linkage, excess solder in the front door power window switch, water infiltration of a potential open wire harness connector inside the front doors, wiring harness chafe on the door check strap, or a damaged Remote Keyless Entry (RKE) key fob.
Nov 16, 2008 | 1996 Mercury Sable
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Nov 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWZ410 Front Load Washer/Dryer Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
