Question about Neff B1421 Electric Single Oven
Hi Being a practical guy ... I have replaced the
Hi Being a practical guy ... I have replaced the Inner Glass in my Neff C67M70 combi/micro. oven ... But then ... also being forgetful ... I cannot rebuild the door ! Inner bit with new glass is fine, it is just the next section : Outer door / next metal window panel / another bit of glass / 2 silver metal strips / 2 black plastic attachments. Anyone out there with any ideas ? Thanks Regards Tony
  • Tony Hordern
    Tony Hordern Oct 11, 2013
    This is not anything to do with B1421 ! Where did that come from?
3 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Cannot re-fit middle glasss into main oven door
this is a new one too me but ill give a shot
ive never seen an over where the supports were all intack
they should be screwed in at least to of them by what i call the hidden screw or plug either the 2 bottom come out or the 2 top ones come out to where the glass slides into position and just put the supports back into place
i was reading reviews on this particular item and clearly by what there describing this is not a very good functioning machine all out of tune from the older style
Posted on May 09, 2008
  • 414 Answers
SOURCE: neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Posted on Nov 23, 2011
Testimonial: "Top class advice. Instructions were extremely clear and accurate. Job done. Had never done anything like this before! Many thanks."
How do we replace the shattered inner glass of the oven?
Anne,
Most oven will have a series of screws that hold the door halves together and you would need remove those so that you can gain access to the glass panel. Some doors only have two screws that also hold the door handle on and you would have to remove just those to gain the access you need. Hope this helps!
Aug 11, 2015 | Combi Ovens
Microwave door glass replacement
yes u can refit it normally.but do it carefully.need more help regarding this let me know .
Jun 16, 2008 | Ovens
How do I tighten a loose handle on a Neff u1661n2gb/05 double oven
There are no screws holding the glass on. You need to pull off the inner glass. It just clips on so just pop a round knife at the top and it should just pop off. Tightening the screws should be easy but you probably need a torx screwdriver from memory
Mar 08, 2015 | Neff U1661 Double circotherm super...
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
The inner glass of my sons built in oven door has fallen out can you please advise how we can fix it thank you it is neff b1420
The inner glass panels are bonded to the frame with a heat proof adhesive.
The chances are you will have to get a complete new door assembly.
Jul 22, 2008 | Neff B1421 Electric Single Oven
Microwave door shattered
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
Neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Apr 28, 2008 | Neff B1421 Electric Single Oven
Cleaning the inside of the glass on the oven door
dont try you will broke something and then gonna think that was better to have a little dirt in there, a tech could do but whats if it comes again....good luck if you insist post back
Aug 07, 2006 | Neff U1421 Double circotherm Electric Oven
Neff B1421 Electric Single Oven Logo
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
