Question about LG BD670 Bluray 3D Player
Connection settings ip mode dns
Kein verbindung mit internet
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Feb 18, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
Could someone pls help me to configure my Samsung GT-B7722. My network Sun Cellular (Philippines) says they do not have the setting for my phone model. Thank you!
Since Sun Cellular does not have specific settings for your phone for an automatic configuration, you can still connect to the internet by configuring your device manually. You just have to look for internet settings in your phone and input the configuration as indicated below.
SUN GPRS Settings (HTTP & WAP)
Connects to:The Internet
Access Point:minternet
User & Password :
Primary DNS:210.23.234.65
Secondary DNS:0.0.0.0
IP Address:
SUN MMS Settings
Connects to:MMS Connection
Access Point:mms
User & Password :
Primary DNS:0.0.0.0
IP Address:
Go to programs-accessories-MMS Setup
MMS Connection
IP:202.138.159.78
Port:9201
Mmsc Address:http://mmscenter.suncellular.com.ph
MMS Download:Auto
Mar 22, 2011 | Samsung SGH-D900 Cellular Phone
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
Songs und Bilder auf CD brennen nicht mehr möglich. Fehlerbeschreibung: Keine Verbindung zu Windows IMAP 12 CD Engine möglich.
Songs und Bilder auf CD brennen nicht mehr mã¶glich. Fehlerbeschreibung: Keine Verbindung zu Windows IMAP 12 CD Engine mã¶glich.
Above Question in English:
Songs and pictures onto a CD no longer mã ¶ possible. Error Description: Unable to connect to Windows 12 CD IMAP Engine mã ¶ possible.
Answer:
Your quesion is not clear and full.
I think:
you have problem when burning cd with Media Player 12.
Go to services in Control Panel > Administrative Tools or type and press enter services.msc at command prompt.
Enable the following service to Automatic mode and press start button:
IMAPI CD-Burning COM Service
Now log off / restart.
See the problem solved or not ?
If the problem is not solved then - fully describe your issue here.
Thanks for using Fixya.
bcdalai
Aug 03, 2010 | Computers & Internet
How do I change the ip address from the lcd display?
hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • Jul 02, 2010 | Zebra Printer 140-751-00000
    Dns error when connecting how do I fix this
    Unstable connection. if you have wireless connection that could be a problem depending on your environment. Try turning off your firewall too by calling your internet server(Comcast,DSL,etc.)
    Jul 31, 2008 | Sony Playstation 3 (PS3) Console
    Cant get internet connection on my ps
    first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
    try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
    - explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
    - purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
    Jul 28, 2008 | Sony Playstation 3 (PS3) Console
    LG BD670 Bluray 3D Player Logo
    22 people viewed this question
    Computer Repairing
    Computer Repairing
