Fax panasonic kxfl612
Call service 1 , call service 2 and call service 3
Call service 1
At this time we recommend you locate an authorized service center using the below link.
Welcome to Panasonic Online Repair
Apr 03, 2014 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic driver free download
Here is the link to the support page. Select the type . You can enter the model number. Sorry nothing pertaining to the KXFL612 model.
http://panasonic.net/pcc/support/office_products.html
Oct 29, 2013 | Office Equipment & Supplies
1. Fax answers on long distant rings. 2/ Can not receive faxs. 3/What does Tam#ID =11 mean?
1.- Distinctive Ring service from your phone company
2.- Cannot receive faxes
3.- Telephone Answering Machine (TAM)
Item 1 check page 31.
Items 2 and 3 check Troubleshooting pages of the Panasonic OPER-MANUAL
Jun 23, 2011 | Panasonic Office Equipment & Supplies
Error code is call service 3 on the Panasonic fax kx-fl422
You need to contact Panasonic Service personnel to resolve any error code that begins with "call service." Please call or e-mail using the following contact information:
Obtain Product Information and Operating Assistance; locate your nearest Retailer/Dealer or Service Center; purchase Parts and Accessories; or make Customer Service and Literature requests at:
http://www.panasonic.com/help
E-mail Panasonic tech support via:
http://www.panasonic.com/contactinfo
For in Limited Warranty programming and Troubleshooting Support:
Office Advantage assistance and Service Location finder: 1-800-211-PANA (7262)
If the Limited Warranty has expired, contact Continued Services Technical Support Line at 1-800-435-7329, for fee based technical support. A credit card will be used to charge this fee.
Mar 07, 2011 | Panasonic Office Equipment & Supplies
Call service 3 panasonic kx-fl612
hello sir i have panasonic fax kx-fl 612 error code is call service 3 pls help us how i can run my fax plz
Jun 24, 2010 | Panasonic KX-FL611 Plain Paper Laser Fax
Hi, i need change number of ring to fax into panasonic 8020e
yep. you can only change it through fax service mode. here check it out:
To enter the Fax Service Mode
  • Press “FAX/EMAIL” key.
  • Press “FUNCTION”, and then “7” keys.
  • Press “MONITOR” four times, then press “*”.
  • Enter the desired code number, or press the “V”, ”/\” arrow keys.
  • Go to function parameter setting, and then press START key
  • Press '4' and then '5' keys or press 'V' to select #045 mode.
  • Enter a number (1 for 1 ring, 2 for two rings...), and then press START key to save.
  • To exit the Fax Service Mode press “STOP” key.
Jan 11, 2010 | Panasonic DP-8020E Black and White Copier
I have one Panasonic fax model no.KX-FM89BX showing call service 2
So, people, really! "Call service"message means CALL the SERVICE! (The problems can be various, so only the service can check wich is is the give problem and solve it.)
Jul 02, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Call Sevice 4
reset the unit..press menu#9000*550 Then press start.Call service 3 has something to do with the temperature of the unit check thermostat @ the fuser unit.replace it because the thermostat is not switching to on/off condition although it reaches its peak temperature.
Mar 17, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
jasbo
jasbo
