Question about Toshiba MD20P1 20 in. TV/DVD Combo
Toshiba md20p1c tv power won't stay on
Toshiba tv power won't stay on. i turn it on with either the remote or on the tv & it turns on for a few seconds then shuts off. I have tried about 75 times and still no luck. The TV/DVD unit was mfg. in June 2004 sn-47Z61016A
  • 1 more comment
  • KLYN21 Nov 30, 2007
    I have the same exact problem with my toshiba tv/dvd combo. It just started today and i have had it for about 3 years now. I have checked for loose cords, and dull batteries and nothing seems to effect the tv shutting off randomly. I dont understand why this is happening. I had another tv for 10 years, though It does make sense that any combo tv would work harder. so specifically lets say I turn the tv on from the remote or on the front of the tv and the first few times it takes a couple seconds and even to a minute and it turns off completely. then the next few tries it turns off in a matter of seconds. by this time I cant keep it on anymore. I rarely ever use it, only for at the most 2 + hours a day.... help! I dont want to have to take it to a repair shop.... I dont know what to do!
  • Anonymous Sep 08, 2008
    el televisor no me enciende
  • Hola7 Nov 11, 2008
    I have have a toshiba md20p1c and the same thing keeps happening, it won't turn on unless i disconnected , but eventually it will turn off again by itself.
The problem is Q401. Change it. It is a 2SC1624 but a 2SC1018 will also work. This solution will work for other Toshiba P combo units.
Posted on Mar 14, 2008
I don't like combo units of any size or kind or make. They are all troublesome and they are all difficult to diagnose and they are all very expensive to repair. Please do not buy another one. You are always better off purchasing separate units; you will get better quality AND the total cost will be less for comparable units. The vcr used in combos is inferior and the tv is overheated because of the extra electronics in the box. So, please stay away from then.
Now, to your problem. The reason is shuts off is the protection circuit that is detecting too much current being drawn from somewhere inside the tv. Probably, the trip level of the protection circuit was set too close the limit at the factory and you really should have taken it back while it was in warranty. Now, due to some aging or component failure it is drawing more current and trips the protection every time.
I would judge the repairs to be quite expensive, relative to the cost of the unit. This is because techs don't like to work on them and they are harder to get inside and probe around to do the diagnostics. So, you are probably looking at a repair bill of $100 plus or minus.
Now, here is the really bad news. YOu can buy a pretty good 13 inch set for $49 and up. You can buy a pretty good vcr for $35 and up. So, you can probably get some good merchandise (at least compared to the 13 inch combo you now have) for less than the repair bill.
However, don't take my word for it and call a couple of shops and ask them to give you some estimate or guesstimate over the phone and whether it is worth fixing. It won't cost anything and you might get lucky by finding some shop that is hurting for business and wants to fix it just to make a few dollars on it. But, normal cost would be a couple of hours of labor and parts, so $75 minimum would be my strongest opinion.
So, your decision may be an economic one rather than a technical one at this stage.
(From AllExperts.com for a similar problem with another TV)
Posted on Nov 12, 2007
SOURCE:
Toshiba 65UL610U Wont stay on
Is the problem with the remote or your TV? Does it stays on if yiou turn your TV on manuall?
If so, you may have a contact problem with the remote and should take it to a repair service to get it cleaned
Jun 08, 2015 | Toshiba Televison & Video
MY CYBER HOME TV WONT STAY ON
The reason for this type of faults are very difficult to detect. Contact any service technician.
Jun 06, 2013 | Cyberhome CH-LCTV 150 15 in. LCD...
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Won't stay on
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
May 22, 2017 | Sony KDL-52EX701 52 in. LED TV
Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
Apr 30, 2012 | Toshiba 40E210U 40 in. LCD TV
Hard to get tv to stay on. comes on then shuts right off??
I have a very similar problem with my same tv. I know you posted this a while ago but if u solved your problem I would love to know how to fix it, mine just went out with that same problem. And vice versa if I get mine fixed.
May 15, 2010 | Toshiba 65H84 65" Rear Projection HDTV
The tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | Toshiba CF36G40 36" TV
Toshiba TV/DVD combo turns on then off again.
try letting it sit for 15-20 minutes unplugged from the wall and maybe try another outlet depending on if u got plugged in to a power strip, possibly pulling to much power from that perticular outlet.
Oct 16, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Toshiba MD20P1 20 in. TV/DVD Combo Logo
501 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
