Question about Moulinex chrono jet iron 220 volts chronojet
Can you tell me how many kilowatts runs the chrono jet steam iron? I have had mine for some time and would like to work out how much it is costing to use. I sew frequently and often leave my iron on for hours at a time.
    Top Expert:
  • Moulinex Master
  • 12,223 Answers
You must use this formula: P=WATTS E= VOLTAGE I=AMPERAJE.
P= E x I+= Watts- example if you have 115voltage x 3amp=345 watts
God bless you
Posted on Oct 11, 2013
Testimonial: "Thank you that helps, but how do I find out how many amps?"
I have a MR jet stream it's making all the right noises, but no steam, the small pump seams to be working it makes a noise when I trigger the button iron gets hot...but no steam.
Try adding vinegar to the iron to dissolve any built up mineral deposits inside the steam passages. Put the vinegar in place of water, heat the iron and let it sit for 10 or so minutes. Dump out the vinegar and put water back in the iron and heat again. if the water starts sputtering out the steam holes, then repeat the process a few times to clear the passages.
May 27, 2018 | Irons
Water leaking from soleplate.....
Your Morphy Richards Jet Stream 42271 Iron is developing a leak. If the leak becomes worse, you may have to replace the iron.
Mar 05, 2018 | Morphy Richards Jet Stream 42271 Iron
Descale
Soak and/or run vinegar or CLR through it. They also make a steam iron cleaner.
May 11, 2013 | Morphy Richards Jet Stream 42271 Iron
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
Mar 13, 2013 | Sunbeam 4214 Iron
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
Iam attempting to fit a new dual cord to my steam generator model 2935 and I have misplaced my drawing of the connections to the iron. Is it possible to get the wiring diagram for the electrical...
The Dual Kilowatt Switch MUST be set to the proper kilowatt rating in accordance and Connect incoming power to floating black pigtail leads labeled "L1" and "L2. keep updated,
Dec 24, 2009 | Tefal Irons
My steam iron will not steam. How do I clean it?
Mix (1 to 5 parts) white vinegar in distilled water and pour into the reservoir. Let sit for an hour or so, then pour out through a coffee filter into a container, then pour back into the iron for another hour. At this point, heat the iron and try the steamer function. The vinegar solution will clean deposits from the steam jets, so don't try to iron anything yet. Keep running solution through until sputtering stops. Wash out the reservoir with distilled water, then refill and steam wash the ports several times to remove the vinegar. If you can get it clean, continue to use only distilled water in the iron.
Sep 07, 2009 | Irons
I have Laurastar steampump model 01-0165. How
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
Aug 01, 2009 | Hamilton Beach Steam Excel 14770 Iron
Tefal iron gv5140
Hmm. Mine has stopped steaming too. Any responses anyone? It heats up and works as a non-steam iron, no problems, but makes no steam noises and does not produce steam.
I had bought it off eBay - a retruned or ex-display product, with no guarantee - at the end of April. Tefal said it would not be cost effective to fix it through them. Does anyone have an idea if there's a component I could try replacing and where would I get it. Alternatively, do you know someone in Sheffield who could try to fix it? Or should I accept my eBay gamble didn't pay off and pay for a new one? It's annoying afer only 5 months - I don't iron very often either!
Sep 19, 2008 | Irons
Moulinex chrono jet iron 220 volts chronojet Logo
57 people viewed this question
Top Moulinex Irons Experts
Are you a Moulinex Iron Expert? Answer questions, earn points and help others
