Question about NXR drgb3001-lp Professional Gas Range, LP gas 30 inch
Oven burners oven wont heat after power outage
When Thermador oven is on and the simmer burner on low-low and the igniter sparks, the oven shuts off and the clock blinks (as if there were a power outage).
Check your earthing, all the way back to the earth stake too for safetys' sake!
Otherwise, try lighting the burner with a gas match instead of the peizeo ignition module >> check ignition module
Oct 16, 2013 | Thermador Ovens
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
No burner/oven heating after house power outage.
try reseting the clock as lots of ovens will not work untill clock is set
Jan 19, 2009 | Amana AER5515QA Electric Kitchen Range
My stove will not heat up
The stove has its own fuse so that even thought the rest of the house is OK then the stove could still be dead.
Have you checked your fuses?
Jan 08, 2009 | Whirlpool RF3020 Electric Kitchen Range
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Had a power outage and since then my inglis digital stove does not work. all the light's come on but no heat on burners or oven.
my control panel doesn't light up for both ovens and the clock too. The porclain stove top all five panel do work... could i have blown a fuses? in the oven its self .
Apr 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
NXR drgb3001-lp Professional Gas Range, LP gas 30 inch Logo
21 people viewed this question
Top NXR Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a NXR Kitchen Range Expert? Answer questions, earn points and help others
