Question about Estate TEDX640JQ Electric Dryer
Pkg of cat treats fell into lint shoot
How can i get it out of there? makes loud noise when running
  • kathy313 Apr 23, 2009
    thanks, I'll try that and let you know if I'm successful.
  • Estate Master
  • 3,361 Answers
Unplug the dryer. Remove the 2 screws at the lint filter location. Remove the rear panel, remove the air vent on the back left side
Use a vacuum to remove the treats.
Posted on Apr 23, 2009
How do I remove a sock that fell through the lint trap?
How To Fix Dryer Lint Trap Problems (Removing Items That ...
? 5:32
https://www.youtube.com/watch?v=Fcw1aPqGiSI
Feb 4, 2015 - Uploaded by UKaToNeN
Have you ever had something fall down into the lint trap on your dryer? It`s happened to more folks than you ...
how do I get sock out of lint filter shoot of electric dryer ...
www.shopyourway.com > Manage My Life > Questions
I'm sorry to hear that a sock fell into your lint screen chute and I would like to assist you. Be sure to unplug the dryer prior to servicing it! Do not run the dryer until you are able to remove the sock! There are two ways to do this.
Nov 29, 2015 | Electrolux Dryers
DRYER MAKES NOISE WHEN DRYER TURNED ON SMALL PLASTIC PEICE FELL INTO DRYER LINT CATCHER
it may have worked its way into the b,lower. u have to remove cabinet and then remove blower cover and try to find it.
Aug 27, 2014 | Kenmore 500 6952 Dryer
What are bonita tuna flakes?
Bonita tuna flakes are a type of cat treat that is high in protein and low in fat. Cats really love this treat and find it addictive. When feeding bonita tuna flakes to your cat, make sure to keep the amount given on low because too much fish can cause ******* tract problems for cats.
Aug 13, 2012 | Cats
Where can I find recipes on how to make cat treats?
I've found a great site that has many different kinds of recipes for cat treats. Follow this link http://www.simplypets.com/pet-recipes/Cat/Treat
Aug 07, 2012 | Cats
I have an old Kenmore dryer that works fairly well. About a week ago it started making a REALLY loud noise when on. It still runs and dries but it is vibrating and I have also noticed a few gray streaks on...
I would check the drum rollers, idler pully and see if something has fell in where the fan is. Also check for lint build up. That is one of the biggest problems not keeping the lint screen clean. It gets stoped up and the fan blade can't turn. Also causes it to get too hot and could cause a fire. Last take the belt off and remove the drum . Run the motor for a short time with nothing hooked to it but the fan and see if the motor is making the noise. Have fun. Hope this helps.As far as I'm concerned you have one of the best machines. I wouldn't buy a new one too much trouble and expence.
May 03, 2011 | Dryers
Sock fell down lint vent and daughter turned on dryer
Turn off you power to the dryer and then,
You could run a coat hanger straightened out with a hook bent on the end of it into the lint vent at try to hook the sock.
But probably you will have to remove the back to follow the lint vent.
You may try to remove the vent hose and run the straightened coat hanger in there to try and remove the sock.
Hope this helps
Sep 30, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Lint fell off trap and down into dryer chute.
for the most if you want to clean it it will take you a while, depending on your model, disconect the unit from the power outlet first,from the back panel remove about 6- to 8 screws an then you will see the inside back panel expose to be vacumm, you'll see the back panel of the shoot that runs behind the dryer, take the i think 4-5 screws an vacumm it, i dont think is going to hurt your machine if a little fell in there, a quick way is try to remove the exhaust tube off the back an insert the vacumm cleaner, to clean the tube going out of the house you can use a strong shopvac, to **** it in or a leaf blower to push it out ...........good luck!
May 28, 2009 | Kenmore Dryers
Drum makes noise after I unscrewed the screws inside the machine.
You will have to remove the drum from the front and replace the drum support cup kit.
May 23, 2009 | Frigidaire FDE647RF Dryer
Winding noise
Did a piece of the lint tray break off into the workings? Maybe stuff fell off the lint tray into the workings. It sounds like you're going to have to have the machine taken apart to find the problem unless you can see something down the lint tray opening, and retrieve it with a hooked piece of wire.
Apr 21, 2009 | Whirlpool Dryers
Estate TEDX640JQ Electric Dryer Logo
63 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
