Question about Tomtom ONE GPS Receiver
How to change time on my tom tom one
I will be grateful if you could kindly advice me of how to chenge the time in my tom tom one. Thank you very much . Please email me at
  • jackrobison1 May 06, 2009
    I simply set the wrong time the first time I used it how do I correct this problem
  • 39 Answers
Change preferences ----> set clock
download manual at
tomtom website ----> support scroll down at the right hand side click Find downloads, on that page look for your product manuals
hope this help
23/Apr/09
Posted on Apr 23, 2009
Tip
Thank you so much for taking the time to write this advice!!! When my washer...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
How do I change the time on my tom tom
The clock on your navigation device is automatically synchronised with the satellite clocks. You can also set the clock manually, for example when the device is indoors and unable to receive a satellite signal. The default setting is to automatically adjust the clock for the current time zone.
How to change clock settings To select the time format and to set the time, follow these steps:
Open the Main menu and tap Settings.
In the Settings menu, tap Set clock.
Select how the time should be displayed, then tap Next.
When you do not have a satellite signal, you are asked if you want to set the time manually.
Note: Since you need to be outside for your navigation device to receive a satellite signal, you might want to immediately set the time manually. The device will then set the time automatically when you next take the device outside.
Tap Yes to set the time manually or tap No to set your device to update the time automatically using GPS satellites.
Hope this was helpful. Thank you for using fixya.
Jan 26, 2011 | Tomtom GPS
Tomtom go740 is always saying "searching for a valid satelite"
The Tom Tom will say searching for a satellite ... under several scenarios.
Place it in the dash of your vehicle in full unobstructed view of the sky. If there are many cell towers, power stations, TV or Radio antenna in the near vicinity, it is possible you may need to drive, or move it around a short distance until it can 'lock on' to a satellite. This can happen in very clustered city environments.
Also, when is the last time, if ever, (no worries I'm just looking for causes) you updated your Tom Tom? In my opinion, the Tom Tom requires more frequent updates (depending upon your performance results) which means going to your local store (discount, electronic, etc) and purchasing a card that is activated at the register, and then at home, typically through a USB cable, you will hook your Tom Tom up to a PC or laptop and at the Tom Tom site (or whenever the card you purchased directs you to) you will type in your code from the card and it will upgrade your Tom Tom to the latest data available, and potentially resolving the 'satellite not found issue.'
I do hope this resolves your problem, if it does I would love hear that from you. A testimonial is always a kind way to say thank you! If this did not resolve your problem, I will continue to assist you until a resolution is reached.
Thank You!
May 16, 2010 | Tomtom ONE XL GPS
Changed alternator and rotor on my 02 tt600 bike
Where the source, lighting and pick-up coil plate are bolted onto the crankcase housing, there should be a mark to indicate optimum position of timing. Generally this provides about 6 degrees of rotation from advanced to retarded timing. If no mark is visible set at the center of allowable movement. Too far Advanced timing will result in possible blowback into induction and Retarded timing causes backfiring into exhausts and very lumpy running. Hopefully the previous problem you had to replace the components have not caused damage to the electronic management system.
Cheers.
May 12, 2010 | Motorcycles
Set time on Skyhawk watch
daer sir
my advice for it will be that once u go through catalouge . may be batterys power is no more there better u change it. or try to pull that nob of adjusting time and then like make it free it might have got stuck somewhere .
thank u sir
Apr 09, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How To change idler Pully on 2000 Kia sadona Van
There is a nut in the middle of the pulley. Remove that nut and slide the pulley off the shaft.
May 30, 2009 | 2003 Kia Sedona
BULOVA U.S.A. MOVEMENT CALIBER 10AK, 21 JEWELS, HANDWIND.
Do not wind it more that about 8-10 turns at a time, do this at bed time and mid day it will give you years of reliable service. If I can be of fiurther assistance do not hesitate,.... ask
Sep 08, 2008 | Bulova Men's Watch
Timing belt of honda civic 1996
TIMING BELT SHOULD BE CHANGED AT 60000 MILES OR 100000 KM,
Aug 13, 2008 | 1996 Honda Civic
Tomtom ONE GPS Receiver Logo
466 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
