Question about HP LaserJet 1020 Printer
A faint curved ink line on each print copy
This has just happened... a hairline curve has suddenly appeared towards the centre of the page. I replaced the cartrige a few weeks ago and  I can't send my letters out like this, particularly as they are related to job applications.
Would really appreciate a response asap!
Thank you Deborah
  • 2 more comments
  • deborah_sho Apr 24, 2009
    Actually, the line finally disappeared after I printed out a number of copies.  The cartrige is an HP and the correct one.  But another problem has occured re alignment & this has happened before.  The A4 paper is slightly smaller than the gages (or whatever you call them) and it's like a hit and miss whether it comes out straight or not. So far wasting good quality paper and it isn't printing straight. Do you know  what the trick is?  Thanks.
    Thank you! I'm just not a techie sort person and I thought the guides were stuck in place but obviously I wasn't moving them hard enough. Such a small thing and such a big difference.  Many thanks:)
  • mweather May 08, 2009
    Hi! This sounds like the same problem I'm encountering -- the 1/8 inch line keeps repeating on the left side of the paper. I'm assuming it's a "smudge" on the roller itself of the toner cartridge. I moved the paper as far as I can to the right but it's still appearing. Any other suggestions? Thanks.
  • Anonymous May 11, 2010
    Does this mark only appear once, or does it repeat down the page.
    If it repeats it is likely a defective toner cartridge. Was it a remanufactured or compatible, as opposed to an original?
Slide the paper tray guides snug against the paper, and it should feed fine
Posted on Apr 24, 2009
  • Anonymous Apr 24, 2009
    My pleasure :)
My bizhub c451 suddenly started printing and copying nothing but colourful dots and lines all over the page. even with a test page i can only see a windows logo and all dots and lines, no text. even
Make sure the ink cartridge is full or new. Get to the "Maintenance" page and try an alinement. (The ink dries and will clog the jets if not used often enough.)
Jan 01, 2015 | Konica Minolta Bizhub C451...
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
Printer is only half printing doc on each line, have done test page, very faint, aligned ink, clean cartridges, all with top v faint and bottom dark ink, new cartridge last fri and was working well,...
Open the rear of the printer and make sure theres no paper jam or broken parts.
Try printing a document with the rear of the printer open and watch to see if anything out of the ordinary happens.
Mar 01, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Making a clean copy of an old fainted typed document
A good, free photo-editor is paint.net.
The best option to go for is "Curves". You will see a single line from the left-bottom to the right top. Pick it somewhere in the middle, and move it up/down to make the fainted gray text go darker, while the lightgray background remains white. You can also move both endpoints, or add additional points to the curve you have created by now.
Play with it, and see what looks the best
Jan 02, 2010 | Acer Aspire One Netbook 8.9" Notebook
Prints faint pages
Compare print copy & photostated copy, is there any difference ?
Dec 11, 2009 | Brother MFC-9440CN Laser Printer
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
How do i get it to print straight?
my hp inject printer d145 start printing straight and nearer to the end it started to print with a leaning margin
The printing ink holding keeps on jamming when printing
Oct 13, 2008 | HP OfficeJet d145 InkJet Printer
My printed and copied pictures have horozontal lines
White lines through copies White lines can appear on a copy in either a horizontal or vertical direction. How the white line appears on the copy will determine the cause and solution. Horizontal lines Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps: 1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below: 1. Verify that there is plain white paper in the Input tray. 2. Press Setup. 3. Press or to select Tools and then press OK. 4. Press or to select Clean Print Cartridge and then press OK. The unit prints a test page. 5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again 2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step. 3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels. 1. Open HP Solution Center. 2. Click Settings. 3. Click Print Settings. 4. Click Printer Toolbox. 5. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab and then click Printer Services button then click the Estimated Ink Levels tab. 6. Replace any ink cartridge that is low on ink. 4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage. 1. Open the front of the unit to access the ink cartridges. 2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process. 3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them. Figure 2: Cleaning the ink cartridge 1 - Clean in the cross-hatched area only 2 - Do not touch the nozzle plate 3 - Clean the copper-colored contacts 4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges. 5. Allow the cartridges to dry before reinserting them. 6. Close the unit, and plug the power cord back in. 7. Print a self-test page to check the results. Follow the steps below to print a self-test page. 1. Press Setup. 2. Press or until Print Report displays and then press OK. 3. Press or until Self-Test Report displays and then press OK. The self-test report prints. 5. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s). Vertical lines Vertical white lines usually indicate the scanner did not calibrate correctly. This can be caused by debris on the scanner glass or white reference pad. Try the following steps: 1. Turn off the HP all-in-one product and unplug the power cord. 2. Open the document cover to access the scanner glass. 3. Using a non abrasive glass cleaner, thoroughly clean the scanner/copier glass, and white lid backing on the inside of the top cover. CAUTION: Spray the cleaner onto the cloth. Never spray fluids directly onto the HP all-in-one product. 4. Plug in the power cord and turn on the HP all-in-one. Let me know what happens, Good Luck, Tim
Mar 14, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP LaserJet 1020 Printer Logo
121 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
