Asus aspire one d150-1bk dead, no lights, no sounds, nothing hapens. I measured the power of the charger and indicates 19v when is not connected but when I conect it to the laptop only had 0.8v. Witch could be the problem?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 156 Answers
Try removing the battery then connect the power and see if it turn on without the battery. Otherwise I suspect a bad power board inside the computer.... most of the time if the adapter is giving the correct voltage before plugging it in... it could indicate a problem if the voltage is then lower after plugging it in however unlikely... although it would be aworth making sure you have the right power adaptor for your computer
Posted on Oct 14, 2013
4 Suggested Answers
chessmaster2
  • 160 Answers
SOURCE: ACer Aspire 5920 laptop completely
the power supply may have failed and needs to be replaced.
Posted on Nov 27, 2008
  • 83 Answers
SOURCE: Power Supply either dead or pretending to be.
Check the fan if there is an air coming out,
Posted on Jan 13, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: Asus x58l laptop
input must be 100-240 V & out put 19V. if its ok then your battery is not ok. visit service center please.
Posted on Jan 30, 2010
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
I cannot turn Asus netbook on - not charging, no indicator lights on
Could be a duff battery, does happen. are you. do you have a ampre meter to check charge
Jan 28, 2013 | Computers & Internet
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Acer aspire 5750 charging problem
The solution to your problem lies in one of the following three areas:
Your charger is faulty and is therefore not able to pass power to your laptops battery.
The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
Your battery is faulty.
If you are sure that your laptop charger is dead and you are in the market for a new one, try the following one:
Replacement Acer Aspire 5750 AC Adapter 90Watt 19V 4.74A
Oct 30, 2012 | Computers & Internet
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
How can you tell if your laptop battery is dead,or that your charger is bad?
Hi, if your mains plug has a fuse, I would check the fuse, if thats ok, put a multimeter on to the end of the of the charger lead and check for around 19v, it will say the exact voltage output on the sticker on your charger.
The green light malfunction indicates a issue with the charger not the battery.
Hope this helps
Best of luck
May 31, 2012 | Dell Computers & Internet
I have a Toshiba U500 00X laptop with 19V power supply which I do not have with me at the moment. I do have an ASUS 19V AC adapter with positive terminal on the inside of the circular plug. The diagram on...
Hi, what your toshiba laptop model and asus laptop model? You can use the asus ac adapter on your toshiba laptop only if the folllowing three conditions are met:
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
For the specifications of the two adapters, you may check it here:
http://www.chargerbuy.com, then decide if it will work or not.
Jul 07, 2011 | Computers & Internet
AFTER KEY TURNED ON NOTHYING HAPENS,,NO SOUNDS NO LIGHTS COMPLETELY DEAD,DODGE CHARGER 06,77K MILES,3.5 L
sounds like a completely dead battery, if the battery is charge and properly connected then check the main fuse.
Apr 28, 2010 | 2006 Dodge Charger
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
