Targa 7200 eq dont know how to wire it - Audio Players & Recorders
3 Suggested Answers
SOURCE: wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
Posted on Jan 02, 2009
  • 77 Answers
SOURCE: i need to know how to wire my targa amp please if
Hello, could you please specify how many channels the amp is, what ohms is it stable down to and what type and how many speakers you want to hook up? Then I can draw you a diagram and send it to your e-mail. You would just send me a private message with your e-mail. Let me know, i'm here to help.
Posted on Aug 23, 2009
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
The low frequencies adjustment is not working when i turn the sub frequency on low it lowers the volume of the bass completely
check the rca cables on the back to see if you might have the sub woofer cable in wrong rca spot
this is how it should be wired from your radio front output a set of rca cables go to the radio input of the eq. if you have sub out on radio it will not be used ... eq takes place of it ... turn off subout on radio ... to use eq or preamp you must have at 2 amps 1 for mids and tweets and 1 for subs to work eq right
then from the eq you have another set of rca cables comming from the front output to your mids and tweet amp and then if you dont have a second amp u wont need rear output move over to the suboutput and run a set of rca cables from eq's sub output to sub amp this is how the audio cable section should be connected if you still dont get it to work proper then then it has a electronic issue and need to warranted out if still in warranty or buy new one .... here is a link to the install manual with a wire diagram for repair shop .....http://www.poweracoustik.com/pa2006/manual%20and%20catalog/Processors/PWM-20.pdf
Dec 27, 2010 | Power Acoustik PWM-20 4-Band Car Equalizer
I have install T 3200 targa card but i dont have driver
Most of the Radeon video cards uses ATI catalyst. Try this site. FOllow the step by step procedure on how to download. Good luck
http://support.amd.com/us/gpudownload/Pages/index.aspx
Aug 19, 2009 | Computers & Internet
I need to know how to wire my targa amp please if
Aug 15, 2009 | Car Audio & Video
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Don't know which is my memory wire
yellow is always memory, make sure that it is connected to an always on positive wire
May 12, 2009 | Pioneer DEH-1600 CD Player
Wiring problem
Usually Sony EQ's have a square, 4-pin connector on the back of them
If your looking at the back of the EQ, the upper left pin is +12V (power), the upper right is the Remote, the lower left it Ground, and the lower right is usually not used, but can sometimes be the Illumination circuit... but again, usually is not used.
Mar 21, 2008 | Sony XE-90MKII 9-Band Car Equalizer
Hooking up an EQ on a Yamaha HTR 5860
Are you nuts? You dont need EQ to this system.This is such a nice syetem,inbuilt EQ gives very good output.Don't try to connect EQ if you are not an engineer.It can be connected with external source
Feb 10, 2007 | Yamaha HTR-5860 Receiver
 Grubhead
Grubhead
