Question about Motorola Mobility TracFone w175 PayAsYouGo Cell Phone
Need to turn virator off and turn on ringer on and how to lock and unlock keys so i qiut bumping buttons i lost manual and havn't used phone in awhile
I have a motorola tracfone and lost my manual I need to no how to turn off ******** and turn on ringer also how to lock and unlock keys so quit bumping the buttons I havn't used phone in awhile
    Scholar:
  • 115 Answers
Here is the link to the manual.. http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/W175g%20-%20USA/US-EN/_Documents/Static%20Files/W175g_UG_.pdf
To answer your question, press and hold the # button to cycle the vibrate on or off.
Posted on Apr 23, 2009
Lost my keytried to pick but failed don't remember how bump key works can you help?
If you have a standard lock,tap the bump key in the last bit while turning the bump key with a slight pressure and it should unlock as fast as your regular key,if you have
experience with the pressure and speed needed.
Apr 28, 2017 | Cars & Trucks
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
The ringer is turned off. How do I turn the ringer on? also can I buy another owners mannual
To set the ringer volume of the base unit, press FUNCTION/EDIT, scroll to Ringer Setting using the up or down arrow keys of the navigator key(lower right of base unit), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the right arrow key to save the setting.
To set the ringer volume of the handset, press the CONF/FUNCTION button(lower left) on the handset, scroll to Ringer Setting using the up or down arrow keys of the navigator key(center of the handset), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the soft key SAVE to save the setting. (There are three softkeys directly under the LCD screen of the handset whose functionality can change according to what is on screen)
The manual can be downloaded from the link below free of charge.
http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF
Mar 28, 2011 | Panasonic KX-TG2770 Phone System w/...
How to change ring tone? Lost manual.
usually this is done one of two ways
if the phone has a menu button
press it once then use the arrow keys until you see "ring" or "ring tone" in the display
then use the arrow keys again and you should hear different ring tones. when you find the one you like press the menu button to lock it in
if the phone has a program button and no menu button
keep pressing the program button until you see "ring tone" in the display.then use the arrow keys until you hear the ring tone you like. then press the program button several times until you exit the programming mode.
you can follow the above steps to set the ringer volume also
Jul 16, 2009 | Uniden Cordless Phone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
2001 Ford Taurus auto locking door lock programming
CLICK HERE for the owners manual you require.
The instructions can be found on page 78.
There are 2 methods to enable/disable this feature. One through your
dealer and the second with a door lock sequence using the following
instructions:
1. Turn the ignition key to RUN, then press the door UNLOCK control
button 3 times.
2. Turn the ignition key to OFF, then press the door UNLOCK control
button 3 times.
3. Turn the ignition key to RUN, within five seconds press the door
UNLOCK control button 1 time.
The user should receive a horn chirp to indicate the system has been
altered.
Pressing the power door UNLOCK control button again will toggle the
Autolock/Relock states.
² Turn ignition to OFF to exit.
Thank you for using FixYa - A FixYa rating is appreciated!!
Jan 28, 2009 | 2001 Ford Taurus
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Jan 17, 2008 | Lands Phones
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Ringer turns off when I don't want it to!
To the best of my knowledge there is no way to disable the feature...Sorry...
Oct 11, 2007 | Motorola Mobility RAZR V3
Motorola Mobility TracFone w175 PayAsYouGo Cell Phone Logo
224 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
