Question about IBM Wheelwriter 30 Typewriter
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
My typewriter (IBM Wheelwriter 5) has a new ribbon in it and advances perfectly - but I can't get it to print out the letters or numbers on paper - I changed print wheels and did everything I know how to do - it's like it's stuck on a stencil setting and it's driving me crazy. HELP!!!
  • Jim Keysor May 11, 2010
    Is the print hammer going forwrd as you type?
  • IBM Master
  • 3,594 Answers
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Posted on Apr 30, 2009
There is a ribbon height adjustment that might have been thrown off when you replaced the ribbon. If it is set too high the printwheel never contacts the ribbon. Try gently pushing down on the part of the ribbon cartridge farthest away from you.
Posted on May 01, 2009
Need help with wheelwriter 3 which is not printing. Works but nothing on paper
See page 3-5 @
http://www.national-elec.com/IBM%20&%20Lexmark%20Typewriter%20operating%20instructions/Wheelwriter-3sII.pdf
Sep 06, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Have a olivetti 1000S typewriter, put in a new cartridge but when I type no printing appears on paper, any ideas
Put a multi part form in it, if it prints on the copies then you have a ribbon issue. If so be sure the ribbon is installed properly and that it isn't twisted (the dull side should face the paper) Try it without the Lift off they sometimes steal the impression.
DickyO
Oct 07, 2011 | Olivetti Lettera 25 Typewriter
Changed the typewriter ribbon because it snapped in two. At first the typewriter would not do anything and was beeping and the "store", 1 1/2 and 3 lights were on. I oiled the carriage as...
do you have a printwheel in this machine (round grey disk with "fingers" evenly spaced around it with the charachters on it)? If not - there's your problem. you can repair the ribbon with a small piece of tape (no wider than the ribbon. stuck to the backside (shiny) of the ribbon then turn the ribbon until the taped part goes into the cartridge a ways. if the ribbon is moving ok and you still have a printwheel installed, make sure the ribbon is not getting caught in the printwheel.
Dec 20, 2010 | Nakajima AX-150 Typewriter
My typewriter all of a sudden just stopped typing letters. im not sure if the ink has run out...it wasn't fading or anything before it stopped working mid typing
The ribbon might have fade out, please try and replace the ribbon or check the ribbon selector if is not for stencil cutting. If is in stencil cutting it wont print on the papers as u type. Thanks
Apr 29, 2010 | Brother ML-300 Typewriter
Installed new ink catridge and it is now just typing gibberish. checked to make sure it is locked, but it still doesn't work. wordsmith 100.
You probably tangled the ribbon or the lift-off tape (LOT) in the printwheel, so it can't spin properly. It can happen with any modern typewriter, but it should be easy to fix:
  1. Turn the typewriter off.
  2. Take the ribbon and LOT out.
  3. Push the hammer assembly (the part that sticks up through the space between the ribbon cartridge and the ribbon itself, when it's installed) back toward the paper to make sure it's snapped into place.
  4. Install the LOT, making sure it's taut, so it doesn't catch in the wheel. It needs to go behind the wheel, between it and the paper.
  5. Do the same for the ribbon. Turn the tightening wheel on the ribbon cassette and the LOT spool, so both are tight.
  6. Turn the power back on. Part of that routine it goes through is to find the "home position" of the printwheel, so it knows where each character is.
It should work now.
Feb 17, 2010 | Smith Corona Wordsmith 100 Typewriter
Try typing on a mulipart form. If it types on the copies and not the orinonal the ribbon is the problem. If it dosen't type on the copies then the plastic cap on the print solenoid is broken.
We sell the cap with installation instructions for 20.00 includes shipping.
DickyO
216-241-0027
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
Nakajima AE710 typewriter
The forms obviously have a glossy surface, a fabric or multi strike ribbon will work. There is a impression control oh the l. side of the keyboard and also a bold feature, try max impression and bold.
DickyO
Mar 27, 2008 | Nakajima AE-740 Typewriter
Typewriter won't type letters
HI.. the hammer solenoid may be faulty..it should make a typing sound when you hit a key.( the printhammer moved and strikes the printwheel) or when you changed ribbons you might have unlatched the printwheel..there is a lever you press to relatch it until it "clicks"
If not that then make sure the ribbon is seated correctly, that it is between the printwheel and the black roller.Also visually inspect the ribbon so it is not caught in the printwheel.
Feb 06, 2008 | Brother ML-300 Typewriter
IBM Wheelwriter 30 Typewriter Logo
486 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
