Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-533hd5 not turn on
I still dont get it Im looking in every place in the internet how to fix my problem,mostly they have the same problem with me,that is the power just turn green for a while and then turn back red,they said in the internet that the fuses broken,but how to fix it? what kind of fuses?how to buy fuses in radioshack?just asking about fuses?and where the location of the fuses it self? picture will help. its a lot of components in there. please help me
  • onc0m Oct 05, 2007
    thank you
    i found it
    i replace it with bigger amp and working perfectly
    thank you for your help
    to everybody
  • Allen Beasley Mar 10, 2008
    I had same problem with my Pioneer SD-533hd5 where it turn itself off immediately after I turned it on. This was after several weeks of the TV randomly cycling itself off then back on. Mostly the I noticed the power cycling in the morning after the TV had been off all night. Didn't seem to occur much once the TV has been awhile.
    After reading the excellent advise provided by guest, I found the middle 4amp fuse in the middle circuit board was blown. Replaced the fuse and now it's working. But several self resets occurred after powering it up and I noticed some green distortion as it was resetting. So now I'm waiting for the other shoe to drop. Somewhere on this forum I read a post from someone who replaced the fuse several times then finally found the green was totally distorted. They replaced an IC chip for a permanent fix. I need to find that post and be ready for some soldering I guess.
You are making a terrible decision to put a bigger fuse in where its not needed. If the scematic states it needs 4 amp then u go wtih that.. before you end up blowing up something else you need to take it to a tech and get it looked at cause you obviously dont understand basic circuitry if you need a picture to find a fuse.. Sorry but you could seriously hurt yourself.
Posted on Feb 18, 2008
Theres 3 boards on the bottom inside of tv. The middle circuit board has 3 small fuses toward the center of the board. Just pop those fuses out and look for the 1 that is broken or burnt. Taken the bad fuse to radio shack and get replacement. Very easy repair.
Posted on Oct 04, 2007
Pioneer SD-533HD5 53 in. Rear Projection HDTV Television - Need Manual ....
ManualsLib has the manual for the SD-533HD5 here: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html . (The manual covers two models.) Once you modify the picture parameters (starting from STD, REF THEATER, GAME), these are stored as the User mode. If you press Menu when done changing the parameters, that input should maintain the User settings for the last setting until you change the Picture type. If you modified the parameters for STD and then return to that input and change the Picture to GAME, any modifications to the GAME picture parameters will become the new User Mode. See page 50 of the manual for the details: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html?page=50#manual .
I hope this helps.
May 27, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
How do i switch my sd-533hd5 to hdtv
the only way to do this is u most upgrade ur cable box to hd box then connected to a component with the color green blue and red on the back of ur tv
Nov 03, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-532hds. the red light is on but when
STK ICS 2 of them replace Both STK392-110 use 180s Mats Electronics has them $10.95 each
1-800-628-1118
Feb 25, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My pioneer sd-533hd5 is 8-9 years old. how do i clean the lanses?
You should be able to access it from the back panel. After you remove the panel, the lenses should be mounted on a platform. If you are careful, you can manuever yourself in far enough to clean the inside of the display screen. Good luck!
Nov 02, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Dec 15, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Power problem (switches to standby)
its the problem of the ics on the main power supply board
Do the IC heat sinks get warm??
If they do not, check fuses F852 - 2AMP, F853 - 1.25AMP, F850 & F851 - ALL 5AMP on the power deflection pcb. THESE ARE NOT GLASS FUSES. They are usually about the size of a 1 watt resistor and either green or orange in color. They are soldered in. The nomenclature is printed on the component side of the board. They are all about centered on the opposite edge of the PCB as the high voltage transformer.
If you have cleaned up the mess you describe you most likely have one of these fuses blown.
if dont have any technical knowledge its advisable to call a technician as it is worth getting it fixed.
thanks.
May 19, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Vertical lines on screen
this is the convergence gone bad. that is what was blowing the fuse. this is the board on the far left. there are two stk`s on this board. stk392-110.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
152 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
