Question about Maytag MSD2756G Side by Side Refrigerator
Maytag fridge freezes up - Maytag MSD2756G Side by Side Refrigerator
    Top Expert:
  • Maytag Master
  • 9,472 Answers
You will need to replace the cold control. Here is the part to order.
Posted on Oct 12, 2013
Maytag performa fridge model# ptb1753grw freezer freezing up and the fridge not getting cool. i defrost freezer remove the ice then the bottom fridge gets cold again. but it keeps freezing up again.
You have one or more of your defrost components that are bad. Defrost heater, defrost thermostat, and defrost timer or board depending on model are the 3 components.
Nov 02, 2017 | Maytag Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
MAYTAG MSD2734GE side-by-side fridge/freezer. The freezer coils on a regular basis (3-6 weeks intervals) will freeze. We will have to remove the coil covers and manually defrost them before it will...
I have written tips pertaining to each of those 2 issues
Drian blocked tip...http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
Evap. coil freezing up tip...http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
i have 2 pictures in the coil freezing up tip and they always for some reason post incorrectly so here they are..oldtech2332_43.jpgoldtech2332_44.jpg
Aug 22, 2011 | Maytag MSD2734GE Side by Side Refrigerator
Maytag fridge is "freezing" liquids
38degrees=33.3fharnhg.you dont say which.but i suspect a faulty probe inside the refrigerator next the thermostat and the last it is low on gas.adrian????.
Mar 15, 2011 | Refrigerators
My freezer portion of my refrigerator keeps freezing up on me, Maytag MZD2766GEW.
Hi Staci, welcome to Fixya. In regards to your fridge freezing up continually ( I assume you have to defrost it manually ). It is likely the defrost comtrol. Your fridge has what`s called an "adaptive defrost control" and it is an electronic control board. That is based on the info provided indicating your model is a Maytag. I`d bet on the defrost control, it is certainly the most common for maytag built fridges such as yours. ( now owned by Whirlpool ) Part # 12002104 and retails for approx. $ 65- $70 via "searspartsdirect.com" or "repairclininc.com". Repair clinic substitutes it to their own part # 948430, but they are one in the same. It will be located in the right rear corner of the fridge section under all the plastic control & light covers. Hope that answer`s your question. Thank`s for coming to "fixya". Please take a moment and rate the solution provided for you here today. Good luck. macmarkus :)
Jul 01, 2010 | Maytag MZD2766G Side by Side Refrigerator
My bottom drawer of my 3 year old Maytag fridge is freezing up all the items I put in it. The fridge is on its lowest setting. What's up?
You mentioned that the fridge is at its lowest settings, try up it a bit so it doesn't freeze up your items.
Feb 04, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
My performa refrigerator,on top,of unit is freezing all the food .where should the dial be set?
The fridge section shouldn't ever freeze anything.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 02, 2009 | Maytag Performa PAV2200
Freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Jan 06, 2009 | Maytag Refrigerators
Maytag MSD2454GR
compressor relay shot. needs ground wire to frame of fridge also.
May 18, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
165 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
