Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Raypack heater says CFH - Raypak Free Hydraulic Lift Gate Delivery - No L...
    Top Expert:
  • Raypak Master
  • 5,775 Answers
Calling for heat
Posted on May 27, 2016
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: I have a Raypack pool
Have you tried using a fine emory cloth to clean the ignition wire terminal? Sometimes oxidation builds up on them, and they play heck making contact. CFH is call for heat, and SPK is spark. Clean or replace the ignition wire good and see what happens. The clicking sound is probably the electronic ignition trying to spark.
Looked on the net, but couldn't find these codes, and noone reported any problems. It could be a temperature sensor- that is the cheapest thing to try first. If that doesn't fix it, it could be a faulty ignition unit.
Here is a good web blog of these systems, and may assist you:
http://blog.poolcenter.com/article.asp?articleid=6050
Good luck, thanks for using FixYa, and hope this helps.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 05, 2010
Why do I get CFH but then no SPK?
CFH = Call For Heat
SPK = Ignitor is Sparking - attempting to ignite raw fuel
In a lot of cases, Pressure Switch opens up, CFH , is cancelled and therefor no ignition sequence.
try cleaning filter really good. If cartridge, may be time for an overnight soak.
May 21, 2015 | Raypak RP2100 DIGITAL POOL HEATER R265
Raypack pool heater trouble codes
check flame sensor if wired 120 volt see wiring on inside of panel
Jun 22, 2014 | Raypak Rp2100 Digital 336k Btu Propane...
Raypack 2100......cfh then spark after a few moments.....what appears to be :Lo.....what could this be
check gas pressure sounds like too small meter especially if furnace or dryer is running call gas company give them added value of all gas operated appliances
May 24, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
What is CFH
CFH stands for "Call For Heat"
CFH means "Call for heat" and SPK means "Spark". They are status codes, not fault codes.
It basically means that the heater is turning on the heat mode and spark should appear shortly after the CFH code appears. At this point the heater should be igniting and the heater heating up.
If you are having a fault issue with the heater, please let us know if there is anything else that we can do for you!
Dec 16, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
What does CFH mean on your pool heater and how do you fix it?
CFH is call for heat and the flame is about to come up. The banging you hear is the water inside the heater overheating to a boil. What you have is a water flow problem. If you have a valve bridging the water into the heater and the water going out be sure this valve is 80-90% closed so it forces water through the heater. If not you may have a problem inside the water manifold on the side of the heater. Their is a water by pass disc inside the header if stuck open will cause the same problem. Also check your baskets and filter to be sure they are clean.
May 07, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
88 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
