Question about Kensington KeyFolio Pro 2 Universal Keyboard
Need passcode to install Kensington K39519us Keyfolio Pro 2 Keyboard
I have a samsung tablet and my kensington keyfolio pro 2 wirelee bluetooth keyboard... it connects to the tablet, is it supposed to?
Hi Lynnette,
Your Samsung Tablet will be on the same Router as the Kensington Keyfolio pro 2 wireless Bluetooth keyboard and would therefore expect it to connect to your Tablet.
Regards
Eric
Jan 07, 2017 | Samsung Computers & Internet
Numbers one two and three won't work on my Kensington keyfolio key pad
Kensington KeyFolio Pro 2 Removable Keyboard Case and Stand For iPad 4...
Can you uninstall it and reinstall it? Or install it for another tablet?
If you get same result and it's new, on warranty,Claim warranty If past warranty, ask how much should cost to repair it
Yo can get it in Amazon for 35 USD
Jun 07, 2015 | Kensington Computers & Internet
Where do i find the keyboard passcode?
Typically when the keyboard is turned on, the device discovers it. Once the device discovers it, you should be able to press connect on the keyboard and the Bluetooth pairing request with the code should pop up on your device. Then you should be able to enter the code on the keyboard, press enter and connect.
May 27, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
When typing on keys it put multiple letters
The keys are sticking. Has something been spilled on it? Try these things:
Compressed air under the keys.
A blunt thin knife to jiggle keys slightly, be careful.
A damp cloth.
Feb 16, 2014 | Kensington KeyFolio Pro 2 Universal...
Passcode
I don't know what passcode is and I don't know where to activat
Apr 25, 2013 | Kensington KeyFolio Pro 2 Universal...
I lost the passkey to my Kensington Keyfolio Pro 2 Universal Bluetooth Keyboard. Is there still a way for me to connect?
Enter 5 digits on the laptop or tablet and press enter, then quickly enter the same on the KeyFolioTM Pro 2 Universal and press enter. Will sync up fine.
Aug 26, 2012 | Kensington KeyFolio Pro 2 Universal...
Kensington KeyFolio Pro 2 Universal Keyboard Logo
191 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
