Question about Harman Multimedia Audio Players & Recorders
Harman kardon avr 4550
My 4550 is not remembering any setting after switching completely off. its starting with FM 87.50 MHz / Logic 7 5.1 / Small Speakers. is there a battery to change? or anything else to fix this problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Harman Multi... Master
  • 924 Answers
There is no battery to fix this issue. There is a Back Up capacitor that serves this function. Nor a DIY repair. If you require more assistance, or would like to inquire about repairing your HK, please visit my website at audioserviceclinic.com and contact me there.
Posted on Dec 19, 2014
5 Suggested Answers
SOURCE: My Harman Kardon receiver (
I used the live chat and the problem was resolved.
Usually the problem are strands of speaker wires which cause shorting and protection shuts off the receiver in order to prevent damage. There was one speaker that I repositioned recently which was causing shorting. I twisted the wires and tightened them in place and my receiver has been working w/o a glitch. I was lucky that I did not have to check all the wire strands on the receiver and all the speakers.
Problem solved and I learned valuable lesson.
Posted on Dec 28, 2008
WolfenHawke
  • 13 Answers
SOURCE: Harman Kardon AVR 135 6.1....AUDIO DELAY???
This model does have a delay function. Programming is on page 19 of the user manual. Go to http://www.harmankardon.com/product_support/interstitial.aspx?sJump=ps&Region=USA&Country=US&Language=ENG select all products, AVR135, and get the owner's guide. If you have trouble with the link, then go to the Harmon Kardon site, and make your way to the support portal and then select all products.
Posted on Nov 26, 2008
SOURCE: Harman Kardon AVR 40 no sound
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
Posted on Sep 06, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
LOST REMOTE OF HARMAN KARDON AVR 4550 MODEL
contact the manufacturer at their 800 number perhaps they can help
Apr 08, 2015 | Harman Kardon Audio Players & Recorders
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I have a Harman Kardon receiver Type AVR 500 RDS. Can I set it to 5ohz or 60 hz as I wish?
Should only set to frequency of your power supply otherwise may damage your receiver
Apr 29, 2011 | Harman Kardon AVR 500 Receiver
Hi, I have a Harman Kardon AVR 300 that I picked up at a local sale. When I power it on, it switches fine to each input except the AM/FM tuner (the preset, tuning, & tuner mode buttons don't seem to...
Hello Sir, Hi, you may try the following
  1. try cleaning the switches
  2. if this does no solve the problem, its the selector circuit. this may be digital, so you need to search the IC that selects the FM mode both with tuning. this is fair complicated.
  3. buy a cheap separate FM tuner, run it on auxiliary input.
Mar 22, 2011 | Harman Kardon AVR 300 Receiver
My harman kardon avr 110 will not play thru the fm. what do I need to hook up to make it work?
It's a RECEIVER, meaning the FM tuner is built-in. That's the only source you don't have to 'hook up'. But you DO have to make sure NO OTHER source is selected.
You don't say if it actually TUNES a station or not. Try an antenna.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/harmonkardan/avr_110.html
Feb 27, 2011 | Harman Kardon AVR 110 Receiver
How to erase preset fm stations and then set my favorite stations in the preset fm stations again
You may have to 'overwrite' the existing stations.
http://www.retrevo.com/support/Harman-Kardon-AVR-210-Receivers-manual/id/386bh148/t/2/
Feb 06, 2011 | Harman Kardon AVR 210 Receiver
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
Apr 10, 2010 | Harman Kardon AVR 35 Receiver
AVR 120 5.1 -dolby surround sound & logic 7.
The problem is fixed...
and every thing sounds great !!
Thanks for the premium assistance to help solve my problem...
Pierre
Dec 07, 2008 | Harman Kardon AVR 120 Receiver
Harman Kardon AVR 500: randomly accelerates volume levels.
The problem is with the actual eltromechanical element on the volume control, my avr 300 does this as well and I'll let you know the secret to avoiding it. There are small indents on the volume control as you turn it, if you leave it half way between indents, it will periodically start reading volume changes, if you're lucky it will go down, if you're unlucky by the time you've noticed it act up your speakers are blown. When you change the volume, make sure the control rests in an indent and the problem will never crop up again. A simple solution if you're the only one that uses the receiver.
Dec 03, 2008 | Harman Kardon AVR 500 Receiver
149 people viewed this question
Top Harman Multimedia Audio Players & Recorders Experts
Steve
berggei
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
