Question about GE Profile Harmony DPGT750EC Electric Dryer
Clothes aren't drying .
Dryer is a 2004 Duct is not blocked with anything and dryer is spinning. Their just is no heat.
  • 207 Answers
Here's what you need to do, I'm very experienced with this particular brand/model dryer:
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
Clean the heck out of your duct even if there is nothing blocking it. Also, excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out that build up inside your dryer.
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
http://genet.geappliances.com/DocSearch/Dispatcher
Best of Luck!
Posted on Apr 23, 2009
  • Jerry Apr 23, 2009
    http://genet.geappliances.com/DocSearch/...
    Best of Luck!
  • dstegner119 Mar 06, 2011
    perfect thank you so much
Seems to heat. I know it's spinning. Why aren't my clothes getting dry?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 18, 2011 | LG DLE5977 Electric Dryer
Takes 4 or 5 cycles to dry clothes.
Most of the time this problem is attributed to a blocked or more precisely, a partially blocked dryer vent system. When a dryer vent is blocked it stops the air flow and the heat backs up into the dryer turning the heat sensors on and off prematurely taking longer for the clothes to dry. Over time this may cause the heat overload fuse to blow and you will have no heat at all.
First take a look at the dryers ducting between the dryer and the wall to make sure the vent duct (normally a flexible style) has not been crushed or kinked.
If the dryer duct to the wall is in good shape then in most cases there is a blockage some where between the wall where the ducting connects to the vent and where it exhausts outside.
The major cause of a blocked dryer duct occurs when the water in the clothes is heated to a high temperature and turned into steam, which is then exhausted out the back of the dryer to outside. As the steam cools on its journey and gets closer to the outside of the house, it tends to get cooler and turns back into water droplets. This is going to be the point where the dried lint, as it escapes past the lint filter, sticks to the newly formed water drops and starts a gradual chocking down of the 4" diameter vent to 3",2",1" and finally stops all flow of air.
Remember, the dryer is designed to exhaust so many cfm's and the more choked the vent the more heat is backed up into the dryer.
If you cannot access the dryer ducting, because it is in the wall or ceiling, to look for the obstruction, then look in the yellow pages or contact the local appliance repair service company and get the name for a good duct cleaning company.
Apr 08, 2010 | Dryers
I have a whirlpool imperial dryer, I am not certain of the age or model number. I replaced the electrical cord after a move with a 4 wire instead of the 3 wire that was on it. The dryer operates it turns...
if it's heating up and the drum is spinning then you have a blocked vent line or the duct that the lint filter slides into is plugged with lint,if your vent line is long blow it out with a leaf blower,like i said you need to clean and vac out the duct that the filter slides into and vac out the inside of dryer where the motor is,you should do this once a year so you don't have a fire and your clothes will dry correctly
Feb 03, 2010 | Whirlpool Dryers
Dryer must run two complete cycles to dry clothes
the first thing to checkis the duct venting and make sure it is not clogged or blocked. when the dryer is running go to the outside of the house where the dryer venting is and look at or feelthe amount of air flow coming out.if the air flow is weak there is a restriction somewhere.if the air flow is good and strong then check the heating element. also the washer may not be spinning out the clothes properly
Jan 24, 2010 | GE DBSR453EBWW Electric Dryer
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doesnt heat up enough to dry clothes
sound like the vent duct going thru the wall to outside is stopped up / check your duct and outside dryer flap to make sure the air is open / if blocked it will take 2-3 times as long to dry and make it seem like the dryer isn't drying / larry
Dec 02, 2008 | Kenmore 62602 Electric Dryer
Clothes not getting dried
Are you sure that the duct is clean and free flowing? If the duct is partially blocked the dryer's efficiency drops dramatically. I would double check the duct at both ends and clean out as required - air flow is very important - with the dryer on - go check the air coming out of he duct outside - if it is very forceful - then the problem is elsewhere - however if only a little bit of sir is coming out - your all plugged up!.
Nov 19, 2008 | Kenmore 63942 Dryer
Roper dryer spins and gets warm but does not dry clothes
Check to see if your air duct is restricted. It wont heat properly unless you have the right air flow. Check the duct from the dryer to the outside of your house too.
Nov 17, 2008 | Dryers
GE Profile Harmony DPGT750EC Electric Dryer Logo
225 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
