Question about Water Heaters
We changed the therostat and it still kicks the reset button?
Our electric water heater keeps kicking the reset button and we have changed the therostat what can be wrong?
    President:
  • 710 Answers
Sound like the heating elements are shorting out. Need to replace them after draininbg the tank. First shut off the breaker. Be safe and good luck
Posted on Apr 24, 2009
I have a miser12 electric that was working fine then while not home the power kicked the breaker off and now no hot water at all.
Remove elements and check continuity between the two terminals. If you have bad, or no continuity,
replace the element.
I suggest that you buy a 1 1/2" ratchet socket because the element wrenches sold today are terrible.
Mar 13, 2017 | Water Water Heaters
Why does the reset button on one of the tanks keep kicking when no water is being used?
The tank is overheating when not in use. If it is an electric water heater, you must replace the upper and lower thermostats as well as the high limit(reset button). If the tank is 10 years old or more, you may want to replace it rather than fix it as the average life of a tank is about 10 years before it starts leaking.
Mar 03, 2016 | Water Water Heaters
What is causing electric tankless hot water heater to be needing red button reset often?
PDF]Tankless Electric (RTE) Troubleshooting - Rheem
www.rheem.com/docs/FetchDocument.aspx?ID=87d15e35-5adf-4e9f...
Tankless Electric (RTE) Troubleshooting. Technical Competence .... For four chamber units (RTE18 & 27) go to paragraph 4T. 9. Conduct OHMS resistance ...
Rheem RTE 27 Series ' Use and Care Manual
https://www.manualowl.com/m/Rheem/RTE-27-Series/Manual/296033
Rheem RTE 27 Series ' Use and Care Manual - Page 1. Use & Care Manual Electric Tankless With Installation Instructions for the Installer Water Heaters The ...
Sep 06, 2015 | Rheem RTE 27 Tankless Electric Water...
Thero. knocks off
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Replace both thermostats. One or the other is sticking, and there is no way to test which one is bad... since test unsticks a stuck thermostat
Gene
Jul 01, 2014 | Reliance 606 Series 40 Gallon Electric...
Red reset button keeps kicking out, i reset button and works fine for a day or two then kicks out again
The reset button kicks out because the thermostat detects overheating.
Anything over 150 degrees, the reset kicks out.
This is caused by 4 things.
1) Bad upper or lower thermostat. Thermostat sticking in 'on' position and elements overheating water.
2) Factory-installed insulation and cover are removed
3) Bad element shorted to ground at center of element, and element continues heating with 120V through the ground wire.
4) Loose wire near upper thermostat, that is shorting and causing heat.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Solution:
Check for missing insulation.
Check for loose and burned wires.
Replace both upper and lower thermostat.
If problems continue, test water heater elements and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If you need more help, add a comment and I will respond.
Oct 29, 2010 | Reliance & 40 Gal Electric Mobile Home...
Kicks off on high side temperature
one of the thermostats has gone bad and it causes the reset to kick...
Check out this tip and also the other links to tips at the bottom of this one...
Electric Hot Water Heater Temperature Adjustment
http://www.fixya.com/support/r4656190-electric_hot_water_heater_temperature
heatman101
Jul 12, 2010 | RELIANCE ELECTRIC WATER HEATER
Rheem Hot Water Cylider Thermostat keeps tripping
Sounds like you have a faulty thermostat.  This is the unit that detects the water temperature, and if it is not where it is set, will kick the switch to allow electricity to flow to the elements you replaced. The thermostats are relatively cheap and if you have the knowledge to change the elements, changing these thermostats should not be a problem.
Mar 07, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Top thermostat reset button kicks out
The top button is connected to the top heater element  which is likely shorting out. Drain the tank below the element that the thermostat is attached to. Remove and replace the element
Jan 24, 2009 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
94 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
